Replacement of 870C and 834B front knuckles: FOUND!!
- Been thanked: 7 times
Hi:
Would the item below be a direct replacement of 870C front steering knuckles?? Anyone has tried??
http://www.ebay.com/itm/Tamiya-53579-TA04-Hard-Front-Upright-TA-04-TA05-TB02-TRF414-TRF415-TNS-B-NIP-/390473718312?pt=UK_ToysGames_RadioControlled_JN&hash=item5aea0c1a28
Any info will be appreciated.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Replacement of 870C front knuckles
I think you have a better chance using optima knuckles (used in optima mid and lazer also and available in cast metal and plastic)
- Has thanked: 1129 times
- Been thanked: 3919 times
It was said once that the rpm carriers would fit both optima and yokomo, the only requirement is that an optima uses an unflanged bearing vs the yok with a flanged. So yes, it stands to reason stock optima knuckles should fit, but you may have to play with bearings and spacing.
Thanks. When you said lazer, were you referring to the old lazer or the newer shaft driven lazer?Mr. ED wrote:I think you have a better chance using optima knuckles (used in optima mid and lazer also and available in cast metal and plastic)
- Mr. ED
- Mr. ED
What did you end up using? I have been wondering what to do next since I am down to my last set.
Looks like the dbo1 tamyia might wwork too, but I am not certain.
Anybody know a good sub for the 870c/early yz10 hubs?
looking for something that works on the rear since that is what I am breaking more of.
I am aware the stock part is the same front and back.
Thanks!
Thanks!
Yokomo 870C, YZ-10, RPM YZ-10, Hot Dog, YR-4 M2, '91 Custom Carbon YZ-10, MR4-BX and some RC10's
- Mr. ED
I think you should be able to use some traxxas parts for the rear: like the ones for the bandit or rustler. They all look similar but have different offsets, so best would be to go to a physical shop and look at the spares they have on hand before buying.
OK, got my hands on the TA04 knuckles finally.
TA04 front knuckles are almost 99% directly replacement for YZ834B front knuckles.
TA04 front knuckles are about 23mm tall but 870C is about 19mm, so you have to shave off 2mm from both top and bottom to accomodate them within the 870C C-hubs. it also would make the width wider by about 1mm on one side, which IMHO is negligible.
Hope this info helps
- Been thanked: 325 times
Could you take a few pics comparing the two? Thanks!tiger1 wrote:OK, got my hands on the TA04 knuckles finally.
- stickboy007
- Been thanked: 55 times
Re: Replacement of 870C and 834B front knuckles: FOUND!!
I took at look at some of my TA02 spares, and I think tiger1 might be onto something here. I can't speak for the TA04, but for the TA02, the front steering knuckles appear to have the same dimensions as the 870C knuckles. The only issue, as tiger1 mentions, is that the Tamiya knuckles are taller. The simple fix is to combine the TA02 steering knuckles with the TA02 C-hubs (GPM Racing makes aluminum parts for each, so that's easy). The TA02 C-hubs do seem to fit within the YZ10 arms without any significant play or binding. I think this has a good shot at working. My magnesium hubs are not broken (yet), so I might wait before trying this conversion (Also, I already have aluminum front arms, and I don't want metal everything for suspension and hubs), but indeed it does appear this may work with minimal if any shimming required.
Then how about Ta01? Can it be a replacement??
- 1476 Views
- 1123 Views
- 2050 Views
Last post by ThomasH
- 1045 Views
Last post by Jay Dub
- 1043 Views
Last post by naushad
- 424 Views
Last post by 59burst
- 1173 Views
Last post by stephenianjames
- 361 Views
Last post by Dadio
