Lazer ZX body choices?
Hi guys. I tried doing a search on here but could not find an answer already. Does anyone know of any newer style bodies that will work on a basically stock ZX? I know that TBG sells the original, but I have never been a huge fan of the original body.
Thanks for any info in advance,
Mike
Mike
Mike Moore - 4th Street R/C Raceway
Re: Lazer ZX body choices?
they make the zx-r body also (so does a group in UK also make one) its a bit different than the zx version.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
It´s possible to fit the Parma Tom Cat repro body from Kamtec
http://www.rc10talk.com/download/file.php?id=82622&mode=view
Gone fishing
Thanks guys. I will look into both of them.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Or this one (the best looking IMO): http://www.ebay.com/itm/New-Kyosho-Lazer-ZX-S-LA122-Bodyshell-Kamtec-repro-/190356851677?pt=LH_DefaultDomain_3&hash=item2c52270bdd
Come and visit the stable
Kamtec do a tomcat shell which was a Parma shell made for this and also used on the tamiya protos, links in my name tag below, still using the original first one (picture shows my dragon paint job on web site) since he made the mold four or five years back. Think it comes with undertray (worth asking as i know he has one to do a mold) and is thicker than most shells so last longer.
Or the zxs shell which i know comes with an undertray. Its a tighter fit and youll need associated servo mounts with the extra spacer to move your servo in more on your chassis to get a perfect fit.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
Jirka, do you know it the undertray for the LWB will work also? Thanks for the help.
- Jirka
- Has thanked: 33 times
- Been thanked: 24 times
It should fit too but if I remember correctly You have cut and install both undertray and body really carefully and find correct position to them. Maybe someone who have done it can tell more details about this especially when repro bodies and undertrays are smaller than originals are. Some references about Lazers with LWB bodies are here in scan section from races between about 1990-1992 as all US Lazer drivers used LWB bodies on their Lazers.
Jirka
Jirka
ZXS shell is basically that with air vents. Ive used on my race car which is a redesigned ZX. Link below to pics of it on my car, shell is still here somewhere but ive redesigned the car much more since this write up.Jirka wrote:LWB Mid will fit. I know It is older but it is much better looking than ZX body.
Jirka
http://www.tamiyaclub.com/showroom_model.asp?cid=80944
Sponser links below
Sponser links below
- 713 Views
Last post by sundevil67
- 1036 Views
- 1696 Views
Last post by Kyosho Fan2
- 1792 Views
Last post by Mr. ED
- 1307 Views
Last post by Mr. ED
- 786 Views
Last post by sandkil
- 492 Views
Last post by korreka
- 1868 Views
Last post by kaiser
