Lazer ZX Body Question
glowster21
Post by glowster21 »
Anyone know if the Long Wheel Base Optima Mid bodies can be made to fit a Lazer ZX?
cpebach
Re: Lazer ZX Body Question
Post by cpebach »
Sure, you can but side cut and trimming of chassis is needed.
glowster21
Trim the chassis? Isn't the Lazer chassis more narrow than the LWB mid? Where would I have to trim?
cpebach
Post by cpebach »
The problem is front and rear side parts of chassis,
Look at the below comparison photos.
Above chassis is my custom made for fitting LWB or ZX-S body.
The chassis laid in bottom is normally designed zx chassis (Cabon optional)
If you really want to leave the chassis, you have to trimm the under tray and body but I can not recommend due to reducing anti-dust.
isobarik
Been thanked: 10 times
Post by isobarik »
1 Its possible to trim youre chassi making it narrover.
2 You can order an specific chassi from fiberlyte that is made for the ZXS and the LWB bodys its narroved and balanced.
http://www.fibre-lyte.co.uk/fl/cars/kyosho/jilazer.html
3 You can get the body to fit making the undertray fit first then followed by the body
mvh isobarik
Kyosho Fan2
Post by Kyosho Fan2 »
On the fibrelyte website the james instone kyosho chassis is the one that fits, and based around the zxs, however the zxs one wont fit your car as its a different car. Your main problem is the position of the servo which needs to be moved inwards. I used an rc10b2 servo mounts and moved it in using the other holes on the chassis.
isobarik
Post by isobarik »
Kyosho Fan2 wrote:On the fibrelyte website the james instone kyosho chassis is the one that fits, and based around the zxs, however the zxs one wont fit your car as its a different car. Your main problem is the position of the servo which needs to be moved inwards. I used an rc10b2 servo mounts and moved it in using the other holes on the chassis.
why the kyosho fan 2 instead of the welshy ???
mvh isobarik
do you have any news regarding the LA-35 ???
i have the LA-111 for you let me know when you got the LAW-20.1
mvh isobarik
Kyosho Fan2
La35 gear cover, i will ask mate, also still awaiting the parts so will chase. Dont worry its been confirmed that the last few in the world are being shipped to me.
I felt like a change with the name. Youll never guess whos turning up to the petit event in january, if you can guess who designed the zx5 then youll be right, and no its not Gill Losi.
isobarik
Post by isobarik »
Kyosho Fan2 wrote:La35 gear cover, i will ask mate, also still awaiting the parts so will chase. Dont worry its been confirmed that the last few in the world are being shipped to me.
Is it shin ????
mvh Isobarik
Kyosho Fan2
Got it in one.
Return to “Kyosho Forum”
