RPM ultra molded buggy body choices??
General info, Q&A.
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
hey guys what bodies besides the losi xx will fit the RPM chassis??
thanks
Re: RPM ultra molded buggy body choices??
in the rpm instruction sheet, it says to use the losi pro se body. i'm waiting for brandon to start those up and get one for mine.
hoopty used a loxi xx-l body on his (iirc).
what rear shock tower do you have...... the rpm worlds or a standard buggy tower?
mrlexan
Post by mrlexan »
Just FYI. Teamblue's body is not truely a Pro body. It's a Junior 2 body. That kit he has up for sale is what he used to make the body. There are a number of minor differences with the Pro, Pro SE, and the Junior 2 bodies. Not really a lot of differences to worry about or to be noticed by the untrained eye, but to the purist it's a different story. There are a number of purist here.
www.gojammedia.com
lowrydesign
scr8p wrote:what rear shock tower do you have...... the rpm worlds or a standard buggy tower?
for now, the standard buggy.. still looking for the worlds tower...
mrlexan wrote:Just FYI. Teamblue's body is not truely a Pro body. It's a Junior 2 body. That kit he has up for sale is what he used to make the body. There are a number of minor differences with the Pro, Pro SE, and the Junior 2 bodies. Not really a lot of differences to worry about or to be noticed by the untrained eye, but to the purist it's a different story. There are a number of purist here.
thank you for the info.. do the Junior 2 or pro bodies fit tho?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
Maybe look for any aftermarket bodies that were inteded to use with an XX. doesn't tower still have some?
Kyosho pro-x should work also I guess: redscampi used an xx on his pro-x.
Someone here used the old traxxas bandit body...Duratrax evader maybe?
since most 1/10 bodies are similar in size it's worth looking around and compare chassis shapes an tower locations; you can come up with something original for yours for sure.
well, the worlds rear tower was designed with the losi body in mind. that's why it's shaped the way it is, and has the incorporated body mount. if your using the standard buggy tower, you can run pretty much any of the associated bodies.
lowrydesign
scr8p wrote:well, the worlds rear tower was designed with the losi body in mind. that's why it's shaped the way it is, and has the incorporated body mount. if your using the standard buggy tower, you can run pretty much any of the associated bodies.
so that makes sense now.. i noticed the protec and viper are too narrow up front to clear the brace, has any one tried to fit a worlds body??
so will the pro se losi body work with a stock tower?
i would think that the pro bodies would sit too high using a standard tower.
