Kyosho Triumph Truck
This turned up in the post today, £45 ebay buy. I bought it with the intention of turning it back to a buggy, but actually quite like it as is.
Just wondering if its a proper conversion kit, or home made. It looks proper, i've attached photo's of the front and rear body mounts. Rear shock mount doesn't have the center body mount from the buggy and it doesn't look like it's been removed by hand. The body looks the same as the Pro XRT.
Anyway, heres the pics....
- losiXXXman
- Been thanked: 5 times
Re: Kyosho Triumph Truck
Front body mount looks like a modified LXT piece to me. Also think that the body is an LXT. Cool truck.
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
When I first saw the front body mount, my first thought was that it was an LXT mount as well. I also agree that its a nice looking truck.losiXXXman wrote:Front body mount looks like a modified LXT piece to me. Also think that the body is an LXT. Cool truck.
Matt
Nice truck
Always liked the look of the triumph. i also remember those speedmaster speedo's they were all the rage back at my local club back in the 80's. i've still got one somewhere i think.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
- Been thanked: 325 times
I'd revert it back to a buggy as well...the Triumph was a great buggy and there aren't too many around...and that's a killer deal too!
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
No reverting! If you read around they were really not that wel received or that good. And more important there are definitely less triumph trucks than buggies on this globe.
I thought the Triumph only came as a buggy, and that this was a mod. Was there a Triumph truck?Mr. ED wrote:No reverting! If you read around they were really not that wel received or that good. And more important there are definitely less triumph trucks than buggies on this globe.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I'll +1 keeping it a truck.
Until the Pro-XRT the best truck Kyosho offered to racers was an Ultima II with monster truck offset wheels. A converted Triumph would've been totally legitimate and likely a better performer.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
I'm pretty sure there was never a Triumph truck. I think he meant to keep it as a truck since it's not a common thing to see them converted to one.Coelacanth wrote:I thought the Triumph only came as a buggy, and that this was a mod. Was there a Triumph truck?Mr. ED wrote:No reverting! If you read around they were really not that wel received or that good. And more important there are definitely less triumph trucks than buggies on this globe.
- Mr. ED
You would think that those huge tires would be hard on the belt system. I personally would change it back to a car. As a truck it looks like all the others but as a car it looks like a Triumph.
If geared properly, it won't be a problem. If you increase or decrease the tire diameter significantly on a car, you'll need to reduce or increase the pinion gear accordingly. I had to do that for my CYANide Optima (onroad conversion with smaller diameter HPI VTA wheels & tires) and my Barney Optima (larger-size 2.2" Axial Rockster wheels and Pro-Line Caliber tires). It helps that I created a gear ratio calculator that uses all the important variables to help determine an ideal rollout ratio.cheropache73 wrote: ↑Thu Nov 09, 2017 5:40 pm You would think that those huge tires would be hard on the belt system. I personally would change it back to a car. As a truck it looks like all the others but as a car it looks like a Triumph.![]()
- 760 Views
Last post by highwayracer
- 31 Replies
- 3563 Views
Last post by USA-1
- 39 Replies
- 4638 Views
Last post by Mr. ED
- 3681 Views
Last post by Brandon G
- 33 Replies
- 4392 Views
Last post by rccars4sal
- 1080 Views
Last post by jkelm24
- 22 Replies
- 4219 Views
Last post by Mr. ED
- 1517 Views
