Correct 93 Works Belts?
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
The correct front belt for the 93 Works is ZC-651C, it has blue ink markings on it that say "Pirelli" and is noted in a German translation of the Japanese instruction manual, I've enlarged the reference:
"Bild.33 Legen Sie den langenR iemen2 651C um das vordereD ifferentialS. chiebenS ie es mit den Kugellagernin
die F0hrungd es vorderenD ifferentialgehduseDs.i e kurze Mitnehmerseiteli egt auf der linkenS eite.S teckenS ie die
Unter lagscheib#e1 2 aufd en Stahlbolzen
Unfortunately there isn't any notation about the rear belt id so does anyone know what the correct part number is for the M3 rear belt for the 93 Works?
I know ZC-656 is a rear M3 belt but has anyone ever seen a ZC-656C belt?
This is all very interesting!
DennisM
Has thanked: 30 times
Been thanked: 62 times
Re: Correct 93 Works Belts?
Post by DennisM »
I have a leaflet from Keil, following my 93 works. Here the belt is named 656c
The belts on my 93 Works are both Pirelli.
my nip zc656 belts doesn´t have the Pirelli logo.
Gone fishing
a01butal
Post by a01butal »
DennisM wrote:I have a leaflet from Keil, following my 93 works. Here the belt is named 656c
pm sent
Can you please scan your Keil leaflet if possible and either post it in Scans Forum or send it to me? I have a similar 91 Works leaflet from CML that list all the parts numbers but don't have anything except the German translation for the 93 and in some respects it is circumspect. Thanks very much for your post and now to try and find the elusive ZC-656C rear belt.
Return to “Yokomo Forum”
