Fine Pitch belts
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Fine Pitch belts
Got these today. The infamous fine pitch belts I'd imagine. Are these rare? Ive not come across these before. Cheers-Jason.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Fine Pitch belts
I saw a fine pitch kit in Japan; including the spur with pulley ( with built-in one way I believe) and the pulley too the front wheels, belts and 2 pulleys for the differentials.
With my new policy just in place; "buy only what you can use yourself" I left it on the hook. It was pretty expensive actually.
- Bormac
Thanks for the insight Eric. I just got these in the mail today from my good friend Rob in Melbourne. He found a nice selection of nip spares for the Yoke's and I needed new belts for my 870c car. This is what turned up and i didnt realise they were the fine pitch till it was too late. If anybody wants these let me know. Cheers-Jason.
- Mr. ED
The teeth don't look that small on the picture actually. Could you compare these belts to what's used in an A&L tranny please?
hey Jason, look what i found in the parts i got, I've put one belt aside for you.
cheers Bullfrog
cheers Bullfrog
- phoenix
- Has thanked: 5 times
- Been thanked: 19 times
Hi Jason, i assume they are quite rare as you don't see them alot. I also got some kits with belts & pulleys and will use one to build my works 93.
- Alex B
- Has thanked: 23 times
- Been thanked: 46 times
Mr. ED wrote:I saw a fine pitch kit in Japan; including the spur with pulley ( with built-in one way I believe) and the pulley too the front wheels, belts and 2 pulleys for the differentials.
They did come with a one way for the spur. The conversion kit I got back in the very early ninties included it and i think it cost around £30 (GBP) very pricey for the time!! The original kit by the way is still in great condition and will be used in my 91 works resto.
- Bormac
Eric I dont have an A&L tranny so I dont know how i may compare the two pitches. These belts have a very similar pitch to the Schumacher CAT's and Procats etc...These definately arent the 870c pitch....
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Jason, your rear drive belt ref #is ZC-653S, assuming that the S goes for small, the stock one looks to be ref #ZC-651
Come and visit the stable
- Mr. ED
you might be right on schumacher using the same pitch as A&L: both use imperial hardware and bearings. While yokomo uses the M3 standard: metric pitch with 3mm per tooth.bormac wrote:Eric I dont have an A&L tranny so I dont know how i may compare the two pitches. These belts have a very similar pitch to the Schumacher CAT's and Procats etc...These definately arent the 870c pitch....
- 937 Views
Last post by mikea96
- 779 Views
Last post by slow_jun
- 1400 Views
Last post by mamadoesntletme
- 755 Views
Last post by DennisM
- 1805 Views
Last post by Spiderman
- 36 Replies
- 5383 Views
Last post by KidAgain
- 921 Views
Last post by Mr. ED
- 22 Replies
- 3187 Views
Last post by Seabass
