upgrading my lazer zx-rr, advice please.
guys,
im planning on a bit of a light resto on my standard lazer zx-rr, id like to throw a few vintage hop ups in to the mix, which is where i need help, i was ony 12 when racing this back in the day so dont have a clue what hop ups were actually around back then, could any kyosho specialists out there give me a few pointers on what to look for?
thanks in advance.
thanks in advance.
Re: upgrading my lazer zx-rr, advice please.
About the only things I can think of to upgrade a zx-rr would be some gpm alloy parts, like shock towers, suspension block pivots. Cross might also have had some alloy parts for lazer or the touring cars. ZX-RR was such high spec already that im not sure any aftermarket parts would be much of an upgrade.
Does the RR have a 6 or 7 cell chassis? If 7 cell slots,, then I know a guy who makes lipo trays to fit, plus some other lazer specific flat carbon parts,, but not RR specific....
Well fyi oople web site in the vintage section has a lot of info to help you. Much more than here.
Not much really needed, teamline front hubs, i used 7.5 degrees but some liked 5 degrees. I didnt like the rr steering plate so used a zx one, lunsford titanium tie rods, alloy rear top deck mount and that was basically it.
Fibrelyte have almost all varieties of towers, chassis etc etc on file so can get easily.
If running it you will need a rear and front belt tensioner, plus would advise upgrading the layshaft to the VTS slipper clutch which Alcyon machines and I have tested and proven this design works and beats newer cars.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
Post pictures of the RR. I would like to see one. Did somebody make a finned motor plate for the RR?
Teamline and a few other companies made alloy parts, however in todays racing using brushless it makes more sense doing the rear top deck mount out of alloy as the heat disapates through the motor plate into that. Works well with me and my 4.5rccars4sal wrote:Post pictures of the RR. I would like to see one. Did somebody make a finned motor plate for the RR?
Sponser links below
Sponser links below
Makes sense. Who makes the rear top deck mount in alloy?
Unsure. Ive had mine machined at a cost.
Sponser links below
Sponser links below
Can you give me the details for the guy that makes the Lippo trays? I have a lazer zx I’m in the middle of restoring but I intend to use a brushless motor and Lippo power. Also any other hop ups for a zx and links to the places I can buy them would be great.rccars4sal wrote: ↑Sat Feb 28, 2015 11:35 am About the only things I can think of to upgrade a zx-rr would be some gpm alloy parts, like shock towers, suspension block pivots. Cross might also have had some alloy parts for lazer or the touring cars. ZX-RR was such high spec already that im not sure any aftermarket parts would be much of an upgrade.
Thanks
- 27 Replies
- 4505 Views
Last post by sgirouard
- 1077 Views
Last post by cooltoys
- 308 Views
Last post by Helmar
- 3154 Views
Last post by JosephS
- 872 Views
Last post by vwjuice
- 770 Views
- 1184 Views
Last post by SRTracer121
- 22 Replies
- 1696 Views
Last post by tizeye
Users browsing this forum: Google [Bot] and 5 guests
