My RC10 4wd....Gomachv and Mini inspired!
wydraz
Post by wydraz »
I haven't posted the full build here as didn't want to distract from the true geniuses behind the concept of using a front Stealth gearbox to make a 4wd converted RC10. Jeff and Mini.
Anyway, I've made my own version using Optima Mid front arms, hubs and carriers - I'll let the pic and videos do the rest of the talking. :) Hope you enjoy. It ran so well I was surprised! Next I think I'll cut down the front stealth box and fabricate a cover for the resulting hole.
Well I stuck in some electrics last night and gave her a test run today and wow! Exceeded all my expectations, it runs great! Thanks again to Mini Eason and Gomachv (Jeff) for the ideas :)
Pre-electrics:
Electrics used:
ESC: Novak Hammer Pro
Motor: Old 19 turn brushed
Servo: Low profile core
Battery: 4200mah shorty LiPo
Wheels: Avante Black Special Pink
Tyres: Vintage worn Schumacher CAT Full spike (1.9"?)
Whilst I'm waiting for my Sidewinder body to arrive I found an old unknown temporary orange body to use. Next I may remove the front Stealth and Dremel it to remove the top part as there is no topshaft used at the front, then fabricate a dust cover to keep the innards clean.
Hope you enjoy the videos :)
Image before running:
The video is in 2 parts as my daughter accidentally pressed the home button on my phone:
Video Part 1
http://youtu.be/[youtube]unuItJ_B7S4[/youtube]
Video Part 2
http://youtu.be/[youtube]6hLR3qSeP14[/youtube]
Reason: fixed youtube links
Been thanked: 3917 times
Re: My RC10 4wd....Gomachv and Mini inspired!
Sweet!!! Lookin good dude!
pumpkinfish
Post by pumpkinfish »
We need a full parts break out so others can do this. I have a couple spare RC10's that would be a perfect candidate!
Great job!!!
wydraz
Post by wydraz »
Here are the parts I used to convert my my new built original Team/Worlds Car to 4wd.
As Jeff and Mini have proven there are various incarnations possible on the theme:
1 x Gomachv nose plate, shock tower and upper link standoffs
1 x rere Stealth case (used in rear, original stealth used in front)
2 x Robinson Racing 26 tooth 5mm 48pitch pinions
2 x 3Racing 18 tooth Pulleys 3RAC-3PY/18 (also planing to try 19's for belt tensioning reasons)
4 x 5x8mm flanged bearings
2 x Tamiya FF03 spur gear shafts
2 x Kyosho Optima Mid front wishbones (dremeled lip off inside)
2 x Kyosho Optima Mid Hubs
2 x Kyosho Optima Mid Hub Carriers + 4 wheel bearings
4 x Kyosho Optima Mid Kingpins
2 x Kyosho Lazer ZX5FS driveshafts
2 x TOP racing 12mm clamping wheel hexes
1 x Set of Avante Black Special Pink Wheels
1 x Spare Battery cup, cut for shorty LiPo
1 x Set of Pargu rear RC10 hex adaptors
1 x Yokomo 870c belt tensioner
Miscellaneous screws and nuts
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
nice !! :)
hugger19
Has thanked: 25 times
Been thanked: 143 times
Post by hugger19 »
Oozzee
Has thanked: 21 times
Post by Oozzee »
Nice job looks great, what tensioner did you use on the rear stealth and how did you attach it to the tranny
The Dreaded 7 - 10 Split
tiger1
Been thanked: 7 times
Post by tiger1 »
Nice work.
May I ask what is front width under this set up?
wydraz
Post by wydraz »
Measured from outside of tyres so greatest distance edge to edge?
I'll check when home ;)
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
what belt, or did I miss that part?
I believe he is using the mip legend belt. We need to cross reference it and see if we can get it from SDP
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Glad to help!
The fact it says SDP on it is a good thing :mrgreen: thanks Aaron
wydraz
Post by wydraz »
Excellent thanks Aaron mine is quite faded :)
tiger1
Post by tiger1 »
wydraz wrote:Measured from outside of tyres so greatest distance edge to edge?
Yes, width overall front edge to edge :)
