Gomachv's 4wd RC10 project- finished!
Been thanked: 3917 times
I'm not entirely sure why I'm starting this project, but every once in a while a thought pops in my head and I finally decided to put it to paper...and g10. The kickup is Kydex for mockup, the rest is basically finished and usable. Bump steer is very little, travel is the same as stock and geometry is very similar to stock (raised upper inner mount to match added height of kyosho caster blocks). The noseplate was copied off a cut down version so the rounded end will get the "V" cut on the final version. Kickup is 10 degrees.
The slipper is just a placeholder for the pulley, I plan to drive it off the back side of the slipper hub (will be cut down) like a GT brake adapter. That pulley will run back to the "master" stealth with the same pulley. I need to research pullies and see what my options are.
clm
Has thanked: 100 times
Been thanked: 205 times
Re: I'm not sure what to call it, and not sure why I'm doing
Post by clm »
Now that looks interesting! I can't wait to see where it goes from here.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
slow_jun
Post by slow_jun »
I was thinking on how the spur would be installed , then I continue to read... ahhh......
up for you sir....
― Confucius
Originally I was thinking i would open it up to fwd or even dual motor but to get everything to line up and to be able to use stock steering and even chassis I had to give that up
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
Well, this certainly is interesting. How much front track are you expecting?
Without measuring, but with the experience from the bullet fwd, using standard old style kyosho wheels puts it at the same front track as an rc10 rear. This is using the kyosho dogbones and front axles. The bullet uses short arms but the front chassis is wider, basically I just narrowed and ran later arms.
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
You MUST turn this into one of those fwd off road buggies!!!!!!!!!!!!
I've been waiting to see someone attempt it for years.
Rayzerp
Post by Rayzerp »
http://www.oople.com/forums/showthread.php?t=86091
Great long running Fwd buggy project here
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Pretty sweet!
If you're not keeping it set up for FWD, maybe you could chop the top shaft portion of the front stealth case off and run the belt from the idlers.
3Racing makes a shed-load of pulleys you can use. They're 4mm bore so will have to be enlarged to fit 3/16" shafts.
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
how to secure the gear box to the kydex ??
minimini wrote:how to secure the gear box to the kydex ??
The Kydex is just for mock up, it will be aluminum- however the trans bolts to the front tower only so the lower just holds the arm mounts. The arm mounts are stock rc10 that have the third hold cut off. The trans is also spaced back with 3/32 plastic which will be g10 also. This puts the outdrives low and forward as far as possible without requiring trimming. Really the only parts modified are the arm mounts and holes for the steering idler.
The trans bolts are the stainless steel ones shown here
integra22t
Post by integra22t »
i would like to see how much wight was added to the front .. it looks like it will be nose heavy .. and if your doing 4wd maybe do a one way bearing for the front
minimini
Post by minimini »
gomachv wrote:Without measuring, but with the experience from the bullet fwd, using standard old style kyosho wheels puts it at the same front track as an rc10 rear. This is using the kyosho dogbones and front axles. The bullet uses short arms but the front chassis is wider, basically I just narrowed and ran later arms.
I think it also depends on what off-set rims you are using.... :)
vsefiream
Post by vsefiream »
This is very similar to the mock up I was using for my 4wd project. I was trying to use a GT transmission but I like this!
askbob
Post by askbob »
Now that is 'Out of the box' thinking. 8)
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarSemrush [Bot] and 6 guests
