Hub question....
General info, Q&A.
NickTheGreek
Hub question....
Post by NickTheGreek »
I need some schooling.
On my re release gold tub I'm thinking about getting a set of the Dhawk rear hubs.
I plan on throwing in the some 3/16" cva's (6371)
Which hubs should I get, the classic hubs (6365) or the worlds (7364)??
On the front end I'm gonna have wide arms and wide axles.
And in general, just so I have an understanding of things, if you just swap the worlds hubs on the classic or visa versa, how does that effect handling??
Bottom Feeder
Has thanked: 13 times
Been thanked: 25 times
Re: Hub question....
Post by Bottom Feeder »
Worlds equivalent.
It shouldn't effect handling at all. Toe-in should be the same at 0 degrees and the location of the top link hole should also be the same. The swap is mainly to facilitate the use of unflanged bearings which the 3/16" axles require.
