Team Suzuki TS-3 RC10 rear threaded wheel hubs
The place for digital versions of catalogs and instruction manuals.
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Post by littleVETTE »
what's included:
2x rear rc10 (1/4") threaded wheel hubs
2x wheel hub lock down nuts
2x 8/32" thin axle nuts
1x nut wrench
1x instruction sheet
the japanese instructions. if anyone could translate it so that there could be a record of it for everyone else, that would be great.
instruction sheet:
basically, from what i learned on my own was that one threaded wheel hub w/ lock nut is notched, and the other threaded wheel hub and lock nut isn't. this notch identification lets you know what wheel hub to mount to the correct axle (left side or right side), so that the lock nut doesn't fly off the wheel hub if you installed them correctly. it also prevents you from cross threading the wrong nut onto the wrong hub.
the threaded wheel hub w/ lock nut that ISN'T notched, the threads go CLOCKWISE.
the threaded wheel hub w/ lock nut that IS notched, the threads go COUNTER-CLOCKWISE.
once you got your threaded wheel hubs on their correct axles the installation is pretty much straight forward. just finish locking down the wheel hubs with the provided thin 8/32" nuts. i've had a helluva a time finding a nut to fit the inside the wheel hubs, to further secure them onto the axles. i've seen pictures of other buggies with these hubs that had nuts fitted properly. but i haven't been able to find one to fit the inside diameter of these wheel hubs. if you know of one post it up.
and finally mount up your wheels and lock them down with the wheel lock nuts.
littleVETTE
Re: Team Suzuki TS-3 RC10 rear threaded wheel hubs
pictures and details updated.
Return to “Vintage Catalogs / Instruction Manual Scans”
