gearing for stealth runner
aconsola
Post by aconsola »
I've got my car back together. I think it is a CE, it has a stealth trans. I am using 2.1" rear 3piece wheels with losi tires. I put in a modern 27t stock motor(one of the unlabeled epic handout types)
What is a good gearing to use for general around the yard bashing?
I'e got 78 and 87t spurs and most pinions from 12-25.
Thanks,
-Anthony
Whiskers
Post by Whiskers »
I don't have much experience with stock motors in the RC10 series, having run Mods. Gearing for just playing around with a stock motor, I would go with the 87 spur/12 pinion for maximum run time. Make sure you monitor motor, speed control, and battery heat.
Otherwise just gear to get a 4 - 4 and 1/2 minute run time if you wanna play the way we did back when.
teshreve
Has thanked: 31 times
Been thanked: 27 times
Post by teshreve »
12 teeth seems very low to me.
I'd start in the high teens and you'll probably end up in the low 20's with the larger spur gear. You may even get into the mid 20's.
Bought my first RC10 in 1989
not that i would ever put an 87 on a buggy, it's a little overkill ( in my opinion ). but if your limited to an 87 and a 78 spur, i'd use the 87 and somewhere near the mid 20's for a pinion.
the only time i used an 87 spur on my 2.25 car, it had a 36 pinion on it. now, that was running d.o., though. the motor just seemed to like the big gears. :wink:
Whiskers
Post by Whiskers »
Ron Jeremy wrote:12 teeth seems very low to me.
Depends on the run time desired, I've run a 93/12 with a 19 turn mod for long run times.
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
Try 18/78.
aconsola
Post by aconsola »
Thanks for all the help,
Now if it would just dry up outsde so I can test it out.
-Anthony
Users browsing this forum: No User AvatarAhrefs [Bot], No User Avatarmikea96 and 4 guests
