6 gear update to newer slipper clutch?
I've got an old 6 gear tranny that needs a rebuild, what is needed to put on a new stock 48P clutch set up or V2 48P slipper clutch set up?
I'll put in new bearings, and new classic gears inside, but what about the thrust bearing set up and and top gears? Can I just use all new classic parts inside?
THX,
Lynn
THX,
Lynn
- Has thanked: 36 times
- Been thanked: 1318 times
Re: 6 gear update to newer slipper clutch?
you can't put a slipper clutch on a 6 gear.
just use all of the re-release stuff for the classic.
- aeiou
That part of the 6-gear transmission is also the diff, so just having a slipper there wouldn't work. You can get other 48P spurs that work on the 6-gear, if that's what you are mainly looking to do.
- Has thanked: 1129 times
- Been thanked: 3919 times
The stealths are going for very little money, $65+, and that gets you the dual slipper too. I'd take that route if you want power handling and efficiency.
- Been thanked: 5 times
Actually, you can run a slipper set up on your 6 gear.
I replaced the diff balls with 1/8" traxxas slipper pegs, with pinned diff rings. Posi drive, great for mud.
Unfortunately, this set up ripped the ends off both of my Rayborn slider shafts when I landed a jump on power running a 9t motor. So in hindsight, not such a practical idea.
Kimbrough makes an 81T 48p spur gear with diff balls. At $6.59, it's a cheap way to get you going.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- Been thanked: 4 times
You no longer had a diff. The Raborn sliders are just JRX2 sliders that were cut down.harvey wrote:Actually, you can run a slipper set up on your 6 gear.
- 4630 Views
Last post by Dirtcar75
- 242 Replies
- 35949 Views
Last post by Mrhistory
- 24 Replies
- 3268 Views
Last post by fredswain
- 2493 Views
Last post by yellabelly
- 1015 Views
Last post by Group B
- 889 Views
Last post by vintage88
- 1099 Views
Last post by rustler85
- 1667 Views
