help: crash back o ring size?
- zoomzoombang
Tried the search function but no size mentioned for the topcat's crash back o-rings. Does anyone know? Thanks.
- LurkingCAT
- Has thanked: 202 times
- Been thanked: 271 times
Re: help: crash back o ring size?
Inner diameter: 22 mm; cross section: 2.5 mm - outer diameter 27 mm, obviously
- zoomzoombang
thanks!LurkingCAT wrote:Inner diameter: 22 mm; cross section: 2.5 mm - outer diameter 27 mm, obviously
- Has thanked: 1129 times
- Been thanked: 3919 times
I converted that to inches and picked up a few, tried them on the bosscat....I'm assuming the 4wd cars use a different band
cause it's very tight with only three on and they are a bear to stretch! Hahaha
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Both the TopCat and the ProCat / BossCat use the same part, U725Y, which is described in the ProCat manual as 21.6 x 2.4... what that measurement actually refers to, well, you've got me....
I got some tension bands a while back for my Nitro 4x4 (nitro Bosscat). They are VERY hard to put on.... but they do allow a small amount of crashback, whilst still keeping the front end firm, so I suppose they'll do for me!
Ahh they must be the right ones then
Since I don't have access to metric orings without ordering, the ones I sourced were 7/8"x3/32"
- LurkingCAT
If you go metric or inches just make sure you get some new good quality nitrile ones. I have been very disappointed with some of the "New old Stock" U725Y floating around. Nitrile isn't ageing gracefully, especially if it has been exposed to light and you never know how they have been stored. So if racing them, go for new ones. If you "need" the originals for a genuine restore I'm sure we can help you out.
- 874 Views
Last post by slapshot1979
- 1025 Views
Last post by besty22
- 812 Views
Last post by justinspeed79
- 543 Views
Last post by CamplinP
- 809 Views
Last post by call-911
- 464 Views
Last post by nvxwax
- 26 Replies
- 4699 Views
Last post by joey_zrl
- 459 Views
Last post by the13bats
