Lipo size for Re-release bulkhead
ratrod63
Post by ratrod63 »
I want to put a re-release rear bulk head into my rc10t so I can run a taller lipo.
Does anyone know the size of the new bulkhead? I just ordered 3 for my projects and want to order some lipos. Maybe a 3s. Any suggestions?
I currently run a Turnigy 4000 mah 2s but I am wanting to go higher mah. Also want to try 3s.
Does anyone know if the front battery tray is different?
Re: Lipo size for Re-release bulkhead
just talking about the lipo, the only real difference in the rear bulkheads between an original and a rere is the rere is left open on the bottom for better battery fitment.
the front battery box is the same as the original.
ratrod63
Post by ratrod63 »
scr8p wrote:just talking about the lipo, the only real difference in the rear bulkheads between an original and a rere is the rere is left open on the bottom for better battery fitment.
Thanks. I thought maybe the hole was molded taller.
you know what..... it is actually. just looked at one of mine and it's like 1mm taller. add that to the bottom being cut out, you get 2, maybe 3 mm more height out of it.
