Another wheel question. Front this time.
The Evader front wheels have been out of stock forever and I want to run my OIN. Do the Thunder Tiger Phoenix BXII front wheels have the same offset as the Evader fronts?
Re: Another wheel question. Front this time.
Skip the Duratrax wheels. I cracked both sides after one day of racing. kind of disappointing. I have since converted my front to hex hubs so I can run AKA wheels.
- hawgfanman
- Has thanked: 14 times
I run the Thunder Tiger wheels on my CE and haven't had any issues. They are the same as a B3 wheel so they work with no problems.
- Been thanked: 81 times
Both thunder tiger and the new worlds rims for the front have the B4 offset. The norm these days for the CE and klien arms are inline steering blocks and gt wide axles.
- hawgfanman
The Thunder Tiger wheels sure don't seem to be a B4 offset to me. I have several sets of these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXALSC&P=Z and run them on my standard wide arm CE with the regular axles and have zero problems. They seem identical to the B3 wheels that I have also.
- Been thanked: 4 times
B3 front wheels have the same offset as B4 wheels. B2 wheels were different.
- Has thanked: 36 times
- Been thanked: 1318 times
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Traxxas T-Maxx wheels have the same offset too
Really? How were B3 wheels a different offset from the B4 wheels? I've got a B3 front end with B4 steering and B4 wheels and it's the exact same width as a B4. Even the outer to outer hinge pin distance is identical. Were the B3 steering components offset that much different?
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
The difference is mostly in the caster blocks. The B3 parts have an offset closer to the original RC10.fredswain wrote:Really? How were B3 wheels a different offset from the B4 wheels? I've got a B3 front end with B4 steering and B4 wheels and it's the exact same width as a B4. Even the outer to outer hinge pin distance is identical. Were the B3 steering components offset that much different?
Throw a set of b3 rims on your car and messure the track withd . You will see the differance in what is called rim offset.fredswain wrote:Really? How were B3 wheels a different offset from the B4 wheels? I've got a B3 front end with B4 steering and B4 wheels and it's the exact same width as a B4. Even the outer to outer hinge pin distance is identical. Were the B3 steering components offset that much different?
I know what offset is. What is confusing is how can a B3 front end and a B4 front end be identical in width from outer king pin to outer kingpin yet use different offset wheels? It has to be in the steering hubs.
- 720 Views
Last post by SteveK
- 719 Views
Last post by LTO_Dave
- 4389 Views
- 648 Views
Last post by juicedcoupe
- 1681 Views
Last post by pumpkinfish
- 32 Replies
- 7903 Views
- 1374 Views
Last post by adam lancia
- 2505 Views
Last post by JK Racing
