Old-time wide 1.6" wheels up front?
General info, Q&A.
SteveK
Post by SteveK »
I got this setup this week:
http://www.ebay.com/itm/250966316600?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_698wt_1180
The front wheels are Tamiya, but I don't see any inserts so the axles must be metric (still to grimy to measure). How could I run a set of wide Associated wheels on the front end?
My original plan was for a buggy-based truck with new parts, but I like how these white parts cleaned up so much I may go with that and pick up a gold chassis and nose, so I'm like to keep the front 'white' if possible. Maybe get somebody with a lathe to drill out some rear wheels for 3/8" flanged bearings?
THUNDERSTRIKE1
Re: Old-time wide 1.6" wheels up front?
Post by THUNDERSTRIKE1 »
You got a pm.DON
SteveK
Post by SteveK »
http://www.hpiracing.com/kitinfo/106626/
I just thought of the HPI Blitz Pro, it has white/gray parts, the front caster blocks and steering knuckles might work well. 1.6" tires will fit on Mini-size wheels with a 12mm hex, so that would work perfectly.
