Looking for Composite Craft two-tier front suspension detail
I just purchased a new Composite Craft two-tiered chassis. I would appreciate any info on what members have used for the front suspension. I know that RPM Worlds front ends are used but they are VERY hard to find so any other suggestions would be greatly appreciated.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: Looking for Composite Craft two-tier front suspension de
You need the RC10T truck front bulkhead not the RPM Worlds for the CC Worlds chassis since you need the nose tube mounting points for the front of the top deck. RPM Worlds bulkhead doesn't have that.
You can use the 10T bulkhead with Dynotech Klien arms or Seabass arms when he does another run. You'll need BST access for the latter.
Thank you, that just saved me a great deal of time looking for the wrong part.
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
This thread should help. It has info and pics:
http://www.rc10talk.com/viewtopic.php?f=35&t=818&start=30
Just received my new Composite Craft two-tiered chassis
My new Composite Craft two-tiered chassis just arrived. Great quality product. I have always wanted one of these so I was happy to learn they still made chassis.
Alright, another new one!! I am looking forward to the build up. Do you already have the RPM parts?
I was told I need 10T parts so I am looking for those now. I have some used ones but I will build this with new parts.
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
10t parts like the front bulkhead, yes. The rear toe blocks are specific to RPM rear worlds configuration (as drilled by CC) as is the entire geometric lay-out. You really can't fudge those parts on that chassis and still have a "normal" width car. That entire chassis is designed around the RPM worlds 91' conversion parts. You can get Dynotech/Klein front and rear arms (same width) but you can't really adjust anything else.trailblazer04 wrote:I was told I need 10T parts so I am looking for those now. I have some used ones but I will build this with new parts.
**courtesy of Fastang**
I asked because I have two extra sets of rear toe blocks. I am willing to part with a set I have that's been dyed yellow. Other than those, you can get the 10T front bulkhead, front shock tower from Aaron, and arms from Seabass or Dynotech/Klein (as mentioned above). I also found that Nitro Stampede front arms work well, see below. Everything else can be stock parts including CVDsCharlie don't surf wrote:10t parts like the front bulkhead, yes. The rear toe blocks are specific to RPM rear worlds configuration (as drilled by CC) as is the entire geometric lay-out. You really can't fudge those parts on that chassis and still have a "normal" width car. That entire chassis is designed around the RPM worlds 91' conversion parts. You can get Dynotech/Klein front and rear arms (same width) but you can't really adjust anything else.trailblazer04 wrote:I was told I need 10T parts so I am looking for those now. I have some used ones but I will build this with new parts.
- JPAE07
Reg - so to confirm ..... The only rpm specific items, not remade by someone else would be the rear arm mounts?
that is correct.
arms, hubs, towers are all remade by one person or more. rear arm mounts are RPM only.
- Has thanked: 36 times
- Been thanked: 1318 times
being as though c.c. makes the worlds chassis again, i'm really surprised no one has decided to knock out some rear arm mounts for them. everything else to complete the chassis is readily available in some way, shape, or form.
want to point out....... i don't believe jake's (seabass) rear arms will work using them on an actual worlds rear setup. they're designed around an "old is new" concept and are longer than a worlds arms. they will physically mount up, but cvd length will be an issue.... i would think.
Glad you mentioned that. I have been told the Klein arms are the same length as the RPMs so I probably drew the assumption that Jake's were the same, sorry.scr8p wrote:want to point out....... i don't believe jake's (seabass) rear arms will work using them on an actual worlds rear setup. they're designed around an "old is new" concept and are longer than a worlds arms. they will physically mount up, but cvd length will be an issue.... i would think.
- 767 Views
Last post by Kcal
- 28 Replies
- 4764 Views
Last post by bearrickster
- 3219 Views
Last post by Harrylarry
- 2819 Views
Last post by carloco8
- 876 Views
Last post by asashaw
- 1486 Views
Last post by Synergy
- 1430 Views
Last post by Dr. Robotnik
- 3138 Views
Last post by GJW
Users browsing this forum: Yandex [Bot] and 4 guests
