blue composite craft
here is what i just got back from the powder coating dude... I was told on good authority that the color is the same as used by associated way back when, but it came out slightly a different blue. (see the pictures of the original noseplate, removed only to compare color)
do you think they used to primer their original chassis first?
- Attachments
- DSCN3807.JPG (84.82 KiB) Viewed 1499 times
- DSCN3803.JPG (79.14 KiB) Viewed 1501 times
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
That looks closer to the blue they used on the anodized tub GT chassis. The coating looks a little heavy on the motorplate, but all I've ever seen powdercoated were chassis and noseplates... the stuff you had done looks more "metallic" than your orig noseplate.
I don't think AE primed anything before coating (IIRC powdercoat does not require primer).
You'll want to use shorter screws on your rear bottom plate, or hack your gear cover... they need to be 4-40 x 1/8" CS.
- Has thanked: 36 times
- Been thanked: 1318 times
- templeofspeed
painter?
are you a painter scr8p? i had a feeling they had to have been primed white because he tried to powdercoat an unstripped chassis (gold) and it came out green, he said this blue was a clear coat with a blue tint in it. he is going to strip the paint and then the anodizing and do it over... I agree badhoopty, I thought the paint looked to thin... what do you guys think?
not metallic
its not metalic, its the flourescent color (thats what the color swatch said in the catalog)
its just that it must (?) need the white primer.
according to the painter, "the yellow, blue and red are still available."
thanks for the info scr8p
the blue
now that i look at the factory blue nosplate it kinda has a slight metal flake finish (very fine) even though it is a flourescent paint. I will post some more pictures in like two weeks after my parts are repainted with the primer first.
thanks again guys
thanks again guys
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
I like the purd blue stuff toTadracket wrote:I like it
Here's my TC Showroom
- 28 Replies
- 4763 Views
Last post by bearrickster
- 3217 Views
Last post by Harrylarry
- 49 Replies
- 7508 Views
Last post by Chewbacca
- 761 Views
Last post by ELF-BMX
- 798 Views
Last post by THUNDERSTRIKE1
- 2472 Views
Last post by TravelinTravis
- 1213 Views
Last post by ericsp2
- 1429 Views
Last post by Dr. Robotnik
Bing [Bot] and 4 guests
