and another 870c project. must be most common yokomo!
rccars4sal
Post by rccars4sal »
All are yz870c/ ae yz10 models I think. Bunch of parts! A bunch of rpm and Andys plastics, machined aluminum bulkheads, all the diffs seem great! Belts seem ok. Mostly good parts. First build is the bling car, fancy parts, all nice and newish looking.
stickboy007
Been thanked: 55 times
Re: and another 870c project. must be most common yokomo!
Post by stickboy007 »
Wow...lotsa parts.
flustorm99
Post by flustorm99 »
so those c hubs...what kind of king pins do you use ??
I believe they are designed for ball bearings so depending on the bearing it might just be a standard screw not a shoulder bolt.
flustorm99
So normal wheel bearings with the lip! Or is there something in the hub to stop the bearings falling out?
Been thanked: 3919 times
Flanged and installed from the inside typically. Stock kingpins will likely fit with the right bearings
flustorm99
Ahah...cheers.
rccars4sal
They were in concert with non flanged bearings and some black king pins. One of the other cars has brass king pins. I think flange bearings would be best. Going to see if I can find some that fit.
flustorm99
So are they actually yr4 c hubs? As i see a few of these floating around and know u need bearings for them
rccars4sal
Not sure. All I know is theyre shiny, and seem to have zero caster. All the parts are used, or at least out of package. Those hubs came on a parts car, much like those 2 skeletons in the picture.
I had read it here on rc10talk somewhere,, and didnt know if it were true,, but I tried it,, and it is!.....Optima mid c hubs and knuckles will work in a pinch. Aside from minor cosmetic differences,, they are a great fit. So,, that opens up more options.
Kyosho hubs also came in a different caster, which opens up a tuning option as well
rccars4sal
Im so tempted to do a hybrid build all lazer optmid and yz mixed up. With hints of anything else on hand,,zx5? ,, perhaps some top force UJs...
stickboy007
ZX5 UJs would fit better.
rccars4sal
By the time Ive finished with yokomos, lazers, progress's, ta01's and xx4's,, there should be enough left overs for a hybrid of sorts. Trying not to venture much past those.
rccars4sal wrote:Im so tempted to do a hybrid build all lazer optmid and yz mixed up. With hints of anything else on hand,,zx5? ,, perhaps some top force UJs...
Go for it! It's quite rewarding to build something unique.
Return to “Yokomo Forum”
