Suspension arm hinge pins for YZ10
trailblazer04
Post by trailblazer04 »
Can anyone tell me what a suitable hinge pin is for the suspension arms on a YZ10. I assumed RC10 pins would work but they are thicker.
Been thanked: 3919 times
Re: Suspension arm hinge pins for YZ10
I was actually going over this today, I didn't find a match for the inners, but the ultima outer fronts are perfect for the yok outer front and rear if you don't mind the one-e-clip design
Stupidly I didn't look at the inner front ultima pins yet...I should go check that
hondaman
Post by hondaman »
If you don't mind a longer hinge pin for the inner ones I used OFNA 3mm pins part# 36170.. Comes with 4 pins and e-clips.. Cool thing is that you can slip on a turnbuckle like on the Works 93.. looks cool and is functional.. 8) I got this info from this site.. :wink:
Shawn
Found the thread I got this info from:http://www.rc10talk.com/viewtopic.php?f=29&t=16827
Return to “Yokomo Forum”
