Source for hinge pins?
Has thanked: 2605 times
Been thanked: 2979 times
The bummer about building up from parts is that the little stuff holds up projects. Things like E-clip hinge pins. I can probably make some out of steel rod, but if there's a commercial source I'd rather buy them and they will probably be nicer than what I make. I don't really want to pay the eBay $50+ for a $2 set of 10. Anyone know if someone like Grainger or McMaster Carr sells them and what they would be called?
RogueIV
Has thanked: 2139 times
Been thanked: 1100 times
Re: Source for hinge pins?
Post by RogueIV »
Frankentruck wrote: Tue Mar 07, 2023 7:34 pm The bummer about building up from parts is that the little stuff holds up projects. Things like E-clip hinge pins. I can probably make some out of steel rod, but if there's a commercial source I'd rather buy them and they will probably be nicer than what I make. I don't really want to pay the eBay $50+ for a $2 set of 10. Anyone know if someone like Grainger or McMaster Carr sells them and what they would be called?
I've only really seen raw pins without grooves on McMaster. I really should make a jig to cut grooves in these things.
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
So true! I have a load of Top Cat parts. I honestly believed I could build 2 from scratch and still have enough spares to run them for ages. 8) But when I tried to refurbish my old one, I had to stop several times and wait for cruciforms, e-clips, etc. :?
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
"Headless Clevis Pins with Retaining Ring Grooves "
no idea where to get them in the right size though
bluewormx
Has thanked: 41 times
Been thanked: 91 times
Post by bluewormx »
JC racing in the UK have it on their "In the pipeline" https://www.jcracingproducts.co.uk/in-the-pipeline/projects-in-progress
They seem to be getting everything done more or less on schedule. :D
For the rear inner hinge pins, RPM is selling them (#70590). I actually need those, so that's a good thing. I'll have to watch for the JC Racing production.
Has thanked: 269 times
Been thanked: 2094 times
Frankentruck wrote: Thu Mar 09, 2023 10:27 pm For the rear inner hinge pins, RPM is selling them (#70590). I actually need those, so that's a good thing. I'll have to watch for the JC Racing production.
Just note that those are the longer ones. Later models (Worlds, late CE and TC, and re-re) used shorter pins.
JosephS
Post by JosephS »
Taking a stroll though the rc10talk.com history turned up using shock shafts as hinge pins.
RogueIV
Post by RogueIV »
JosephS wrote: Fri Mar 10, 2023 12:24 am
There's a reason i saved all those spent shock shafts over the years....at least now there's a reason.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
juicedcoupe wrote: Thu Mar 09, 2023 11:16 pm
Hey Cru ! Go balls out 8)
Users browsing this forum: User avatarGoMachV and 4 guests
