B4 Avid RC Associated Motor Centering Kit for stealth 2.25
General info, Q&A.
slow_jun
Post by slow_jun »
I don't know if this has been done but will this work for our 2.25 stealth tranny?
http://www.amainhobbies.com/product_info.php/cPath/1_25_1450_2919/products_id/266169/n/Avid-RC-Associated-Motor-Centering-Kit
any pics installed will be appreciated.
just interested with the top shaft and the screws...
thanks,
― Confucius
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Re: B4 Avid RC Associated Motor Centering Kit for stealth 2.
Post by Y'ernat Al »
Interesting. Avid, my wallet in my pocket is a problem, can you lighten it so I can walk straighter? :D
Unless the 2.25 is in graphite, the motor plate conection with the tub would have to be re done. And either way, the inside camber link on the bulkhead would probably be a no go on that right side, and one would probably want to go double-stuffed felt gaskets. Otherwise, knock yourself out.
I myself have a couple years of practice to get to where I'd be able to tell the difference. :lol:
- Brian -
My Gallery
that topshaft won't fit in a 2.25 trans. it has the spacer built in that must be left off.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Could probably do the same thing with a Hydradrive shaft and a few washers between the trans spacers and motor plate. Would have to use a B4 slipper too.
Y'ernat Al
scr8p wrote:that topshaft won't fit in a 2.25 trans. it has the spacer built in that must be left off.
Good eyes.
- Brian -
My Gallery
i wanted to pick up one of those topshafts for my b1.5 runner when i picked up the triad slipper for it. but that darn spacer......
i think the next guy that makes a 2.25 stealth trans case should really think about designing the topshaft area like the modern cars. that way, topshafts like the one from avid, and the one made by mip will be able to be used.
slow_jun
Post by slow_jun »
Thanks for the input guys,that saves me a lot of headacheand $26 buks plus shipping. ;-)
― Confucius
abailey21
Post by abailey21 »
scr8p wrote:i wanted to pick up one of those topshafts for my b1.5 runner when i picked up the triad slipper for it. but that darn spacer......
Can't you find someone with a small lathe to turn down the spacer?
i'm sure i could have. but using an early b4 topshaft and not worrying about centering the motor was a lot easier. :wink: :lol:
you also have to make sure the shaft diameter between the spacer and gear is 3/16". it looks like it is, but if it's smaller, it definitely isn't worth the hassle.
slow_jun
Post by slow_jun »
I was also thinking of doing that, just for the sake of doing something... you know.. time... killing... :lol: :lol:
but there is also the ball stud (below the wing mount) you need to move that and change the location.
well , hope someone on here will make it their next WOIN upgrades.... other than that, its all doable. with time and patience.
― Confucius
chophead69
Post by chophead69 »
If anyone wanted to use that top shaft from mip I could turn it down for ya. I had been thinking about running that same top shaft.just because its aluminum to go with my light weith out drives and aluminum diff gear I got from klien.
My pop always said i had to many iron's in the fire
harvey
Post by harvey »
That Mip alloy top shaft is 1/4" on the right side so all you have to do is use a 3/8x1/4 flangeless bearing, and bore out the opening in the tranny to a bit larger than that. I just ran a1/4" bit in and out until it cleared. I also like to use the 3/16" id crush washers from the tc3 trans shim kit to provide a positive stop for the slipper plates, rather than butting the inner plate up against the edge of the flats.
slow_jun
Post by slow_jun »
Pics?
― Confucius
