So I have a servo that for some reason when in the car wont center. when I pulled it out afterwards, it centers again. any ideas whats going on?
its a LHS ls-500 bb mg servo
im already replacing it with a savox servo but it still seems like its worth keeping.
Servo not centering
- Been thanked: 5 times
Re: Servo not centering
How does the steering work with no servo in place? is it smooth? Try working the suspension while you steer with your fingers, sometimes the steering binds at different points in the travel.
- Has thanked: 21 times
could it be a stripped gear inside the servo, wont centre under load because of the torque/pressure on it causing it to slip
The Dreaded 7 - 10 Split
yep, could be binding in the suspension. also, load the servo with your fingers while you exercise it on the bench, and see if adding some load to it prevents the centering. usually bad centering is the travel potentiometer. you could disassemble and look for broken gears or a loose potentiometer.
- 2437 Views
Last post by slow_jun
- 906 Views
Last post by SmallScaleSmitty
- 1773 Views
Last post by surgetek
- 635 Views
Last post by slvrback
- 1868 Views
- 635 Views
Last post by nvxwax
- 786 Views
Last post by shane
- 519 Views
Last post by treehugger
