Super duty rear arm mounts
Sixtysixdeuce
Post by Sixtysixdeuce »
I finally got tired of loose screws, stripped hols and busted mounts. Not that they're horribly expensive, especially with the re-release stuff, but it's still a nuisance to be replacing rear arm mounts on a regular basis. So tonight I grabbed a chunk of 7075-T6 aluminum and set to work on my little mill.
Took about three hours to do the pair, since this mill is little more than a glorified drill press: a little sloppy and 100% manual adjustments and operation. Lots of triple checking everything to make sure you're squared up, and careful passes to prevent unwanted movement. But in the end, the finished product can be pretty decent. You'll notice slight variations from one side to the next, as I really don't do measuring (and sometimes the mills walk out of the chuck). I just kind of eyeball everything, and in this case, held the OEM nylon mounts up against my work pieces to set the angles.
Hopefully I will never, ever have another issue with arm mounts.
They're affixed to my 4mm carbon fiber chassis with stainless screws, and they are slobbered with red loctite!
Now I just have to do rear hub carriers, front arm mounts, front caster blocks and front steering blocks! Been through this once before on one of my GTs, which sports handmade 6061-T6 arms with steel hub carriers, caster blocks and steering blocks. Time consuming and labor intensive, but it's pretty much a one-time deal.
slow_jun
Re: Super duty rear arm mounts
Post by slow_jun »
nice, hope you can let peeps here have one also...
― Confucius
myfordcnc
Post by myfordcnc »
these days i feel like I'm in an alloy wonderland. Love it. 8)
Sixtysixdeuce
I wish I had the capacity to do production, but all these custom parts are hand crafted one-offs; Duplicates are just as difficult as the first.
That said, I do plan to check with a local plastics manufacturer and friend who has automated CNC equipment, see what it would run to do 50 or 100 like this. I will definitely give the folks here first dibs, but it may require preordering if I can't foot the initial bill myself.
Sixtysixdeuce
Now have super duty hub carriers to match:
marlo
Has thanked: 18 times
Been thanked: 22 times
Post by marlo »
You know what, That's not half bad, I think they turned out pretty good :wink:
Has thanked: 1106 times
Been thanked: 3822 times
Needs more purple :lol:
No but seriously those look great! Especially to know your machining them by hand. Very cool
janaya
Post by janaya »
Count me in if they can do a run of them for you.
Javier -
Phin
Has thanked: 83 times
Been thanked: 236 times
Post by Phin »
flipwils11
Been thanked: 19 times
Post by flipwils11 »
Very impressive to work to get done by hand. However, you may kill me now, but I have a pair of aluminum HG rear carriers for an rc10 I would have sold you!
Phin
Post by Phin »
flipwils11 wrote:...I have a pair of aluminum HG rear carriers for an rc10 I would have sold you!
But then he wouldn't have gotten the hours of enjoyable stress spent making his own, and the kudos for a job well done. ;)
RC104ever
Post by RC104ever »
I would love a set of rear arm mounts! If you do this, I'm in. Missed out on the ones Atlas made.
- Chris
Lots of cars...so many cars
Users browsing this forum: No User Avatarharvey and 3 guests
