10t3 rear arm mounts
JesterRc
Post by JesterRc »
Does anyone know where I may find some 0 degree arm mounts for the t3
broodenburg
Has thanked: 35 times
Been thanked: 10 times
Re: 10t3 rear arm mounts
Post by broodenburg »
the standard version has 3 degr. but if you use the washer underneath that is effectivelijk reduced to 1,5 degr.
0 degr. versions pop up on ebay every now and then. But why would you want to use the 0 deg. version?
JesterRc
Post by JesterRc »
0 degree for racing carpet oval.
JesterRc
Post by JesterRc »
Another question would be....does the rear arm mounts from the 10gt match up..
JesterRc wrote:Another question would be....does the rear arm mounts from the 10gt match up..
GT mounts won't work.
If you're not already a member of dirtoval.com, sign up and post up a wanted ad. The only ones I can think of would be Kranzel's aluminum b3 terminator mounts, but I'm sure they've been out of production a long time. You could even try calling Kranzel's Hobbies. Who knows, they may have some kickin' around.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Don´t know if it´s possible to mount 3 degrees 10T hubs reversed (left to right) on the T3 arms?
Gone fishing
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Like Dennis said,
swap the rear hub carriers,
Left on right side, right on left side.
= 0 degree toe in.
Cheers, Dave. :)
Return to “RC10 Truck Forum”
