10T Gearing for brushed motors
I am looking for a brushed motor gearing chart for my new truck. Couldn't find it in the PDF's AE has on their website for the 10T. Usually they have one in the instruction manual but couldn't find it.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- Been thanked: 4 times
Re: 10T Gearing for brushed motors
With mod motor i run 17 to 21 pinion stock 20 to 24 pinion its a trial an error haft to see how hot the motor is after running.If you spit on it an it sizzles its way too hot ,go down a couple teeth if is,don
The original Stealth transmission ratio is 2.25:1, so you can use math (somehow) to compare the suggested ratios to the T4, which uses a 2.6:1 internal ratio.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Ryan, as a general rule, I drop 4 teeth on the pinion when going from "modern" trans (2.6) to the 2.25 stealth.
So if a T4.x gearing is 23/81, start with 19/81
- 1318 Views
Last post by wyldbill
- 1535 Views
Last post by REMJ666
- 1861 Views
Last post by i crash cars
- 1414 Views
Last post by RC104ever
- 1224 Views
Last post by Lowgear
- 2302 Views
- 1381 Views
Last post by jeekelemental
- 1562 Views
Last post by ChisaiKuso
Users browsing this forum: Mojeek [Bot] and 4 guests
