10T gearing ?
- 20SMOKE
- Regular Member
10T gearing ?
what is a descent starting point for stock and 19t pinion and spur. it does have the stock trans
only asking is that the truck came with motor and battery and the bat gets about 175+ during a few min run
JAMIE W
HIGHVELOCITY RACING_BMI RACING_TEAM TEKIN_J CONCEPTS_TEAM ASSOCIATED
- Has thanked: 183 times
- Been thanked: 157 times
have you tried different batteries?
i dont know much since i'm just starting to use these things and not shelf them, but an 81 seems kinda small to me for a 10t.
i would just use bigger spurs and smaller pinions until it didnt heat up anymore.
the rpm tranny is pretty nice, its higher ratio may help your rig run cooler. i say get one while theyre still available with how things are going lately.
- Has thanked: 36 times
- Been thanked: 1318 times
you want to be around an 87, if not taller. depending on how and where you use the truck. an 81 with those tall tires is just too small. especially with a 2.25. it would be better with the lower 2.65 ratio trans. but even with that, it'd still be too small.
the 2.65 will definately get you off the corners better.
i currently race my rc-10t based oval truck with a stocker on a short 125 foot oval with a 19-90 pinion spur combination and my motors come off the track after 5 minn. at 95 to 100 degrees according to my temp gauge. i agree that the larger spur really helps turn thoes 4" tires but i am also running 2.3 ratio thorp 64 pitch tranny gears inside. this gives a final drive ratio of 10.89 this is the ideal ratio for my track it peaks out about 2 foot from the turn and is a rocket off the corners.
- 1046 Views
Last post by JK Racing
- 1861 Views
Last post by i crash cars
- 784 Views
Last post by Group B
- 37 Replies
- 6401 Views
Last post by Jim85IROC
- 1950 Views
Last post by ca-rj
- 30 Replies
- 7127 Views
- 6177 Views
- 609 Views
Last post by styarr
