T2 slipper- was there a running change?
- Has thanked: 1129 times
- Been thanked: 3919 times
Did associated make any running changes on the T2 slipper? I recall late GT's and I thought T2's coming with the new style slipper that came with the B2. Can anyone confirm? I know they are compatible, just want to make sure it is proper
- Has thanked: 36 times
- Been thanked: 1318 times
Re: T2 slipper- was there a running change?
the t2 and b2 used the same slipper as the original stealth. the inner was different on a gt do to the brake disc.
b3 and t3 used the second design.
Ahh well it's the B3 style I'm thinking of then, the gt originally used the standard early slipper with a longer roll pin for the brake hub. Later they switched to the newer slipper that uses the large bushing instead of the small one. I could swear the T2 was a running change as well but maybe not
was there a hex that slipped on to the standard stealth inner hub on a gt or was the hex built in? i don't remember how mine was and i only ever had one gt. i could give 2 sh--s about gas cars. the only reason i had it was because i got it for free.
It was two pieces with a long roll pin, and usually ended up stripping out until you went to a metal brake adapter
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
Wasn't there a running change in the B3/T3 slipper from a yellow-ish slipper pad (I don't know the part number) to a slightly larger diameter white slipper pad (ASC9253)?
-dldiaz
- Been thanked: 5 times
The brake hex was an add on that slipped over the hub.
Edit: speedracer beat me too it... and yeah the plastic brake hex was worthless!
Yep- and that's the running change I was hoping to find dated back to the T2. Doesn't sound promising thodldiaz wrote:Wasn't there a running change in the B3/T3 slipper from a yellow-ish slipper pad (I don't know the part number) to a slightly larger diameter white slipper pad (ASC9253)?
- 1783 Views
- 1672 Views
Last post by mdutcher
- 3224 Views
Last post by CBR240
- 3104 Views
- 1707 Views
Last post by Lowgear
- 833 Views
Last post by Halgar
- 570 Views
Last post by markt311
- 22 Replies
- 5711 Views
Last post by Lonestar
