Lazer zx screws
bully
Been thanked: 6 times
Lazer zx screws
Post by bully »
Hi everyone, i picked up a zx an was thinking about replacing the phillips screws with hex heads so i bought the rcscrewz zxr kit. My question is did they do away with most of the 2.6mm screws for the zx cos this screw kit doesn't seem to have many of them at all only 8 at most? Also are people that run the zx,zxr series doing away with the fixed rod ends an using ball studs an standard rod ends? Thanks for the input everyone greatly appreciated... :mrgreen:
DennisM
Has thanked: 30 times
Been thanked: 62 times
Re: Lazer zx screws
Post by DennisM »
ZX with fixed rod ends?
I´m not sure that I understand, could You please post a picture?
Sounds like You might have a Lazer alpha/2000?
Gone fishing
bully
Re: Lazer zx screws
Post by bully »
The standard rod end with ball an screw i mean..Do people replace em with ball studs and rpm type rod ends?
j0pp3
Re: Lazer zx screws
Post by j0pp3 »
bully wrote:The standard rod end with ball an screw i mean..Do people replace em with ball studs and rpm type rod ends?
It's possible, yes. I did that to one of my Optima Mids that has the same rod ends and balls. Replaced them with RPM rod ends and associated balls (2.6mm threads).
Cheers
Joel
DennisM
Re: Lazer zx screws
Post by DennisM »
Kyosho still produces and sell the stock ball ends.
Gone fishing
highwayracer
Re: Lazer zx screws
Post by highwayracer »
hey Adam,
I used RPM rod ends and associated ball studs on a lazer that I had. The only reason I did it was to add color to the car.
If you will be switching to the ball stud, try to use a nut on the other end to hold the ball stud in place. You'll be switching from 3mm to 4-40...and it may be a little loose. Yokomo uses a similar ball stud where you can use the RPM ends, but the stud has a 3mm thread. However, it might be a lot easier just to use the RPM/associated set up.
Regards,
Roger
bully
Re: Lazer zx screws
Post by bully »
Thanks everyone,i got cpl packs of the standard rod ends so probably just use them for it thanks...
Welshy40
Re: Lazer zx screws
Post by Welshy40 »
Hex screws big heads i swear by, made a rear belt change possible in under five mins if it broke. The very front rod end i didnt like as the long plastic bent joint cup that goes into the front hub limited travel so opted for putting a ball joint into the inner hole on the castor block so i could use a straight and shorter tie rod and gave better travel.
Also i use associatedball joints all round as well. Easier to maintain as well as less slop and looks much better
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
stickboy007
Been thanked: 55 times
Re: Lazer zx screws
Post by stickboy007 »
highwayracer, is that steering rack from A&L? They have one for the Ultima and another for the Optima, but none specifically for the Lazer. Are you using the Optima rack?
bully
Re: Lazer zx screws
Post by bully »
Yeh roger mate that is one killa lazer,mmmm i am drooling all over the keyboard
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarGoogle Adsense [Bot] and 8 guests
