Screws
General info, Q&A.
Caine
Screws
Post by Caine »
Does anywhere do stainless steel replacement chassis screws for the RC10 and 10T at all?
nvxwax
Re: Screws
Post by nvxwax »
RCScrewz
http://www.rcscrewz.com/index2.php/stainless-screw-kits-cars-trucks/associated-screw-kits/cPath/1_195
And
fastener-express
http://www.fastener-express.com/flat-head-phillips-machine-screws-82-degrees-stainless.aspx
I dont know the size off hand but they should have them (I think they are 8-32 but im not sure the degrees)
Has thanked: 359 times
Been thanked: 470 times
Re: Screws
8/32 @ 100 deg, 4/40 @ 82 deg
nvxwax
Re: Screws
Post by nvxwax »
Charlie don't surf wrote:8/32 @ 100 deg, 4/40 @ 82 deg
Yeah, What he said :)
Caine
Re: Screws
Post by Caine »
Most excellent, ordered from RCSCREWZ. Should have plenty of spares in there too.
Thanks guys your knowledge has helped me so much these past few months to get my rc's on the road!
SteveK
Re: Screws
Post by SteveK »
And metric screws are 90 degrees. What kind of a maniac decided this? And McMaster lists both 82 and 100 for their 8-32 screws, depending on the length. I wonder what that's about.
I still need to pick up a 90 degree countersink, looks like a need a 100 degree as well. Fortunately they are not that expensive, and will last a long time.
PBR Allstar
Re: Screws
Post by PBR Allstar »
SteveK wrote: I still need to pick up a 90 degree countersink, looks like a need a 100 degree as well. Fortunately they are not that expensive, and will last a long time.
as long as you don't get them near carbon or fiberglass!
SteveK
Re: Screws
Post by SteveK »
Legit? I haven't noticed any problems, except the hole in this particular fiberglass I have isn't very true, but I'm not sure if it's the material that's very rough or the countersink bit wasn't that good to begin with.
Re: Screws
composites are abrasive. they will wear tooling out faster than metals, but you would have to make a heap of countersunk holes before you'd really notice.....though they won't cut as sweet after the first dozen times or so they will get the job done.
