lazer zx-r screws
Tamiyaterror
lazer zx-r screws
Post by Tamiyaterror »
hi all,
im looking to replace the tired looking screws on my lazer zx-r, ideally with like for like replacements. did kyosho ever make a complete screw set for this car?
i remember yokomo making one for the dogfighters around at that time.
any help / suggestions would be greatly recieved.
many thanks
chris
Re: lazer zx-r screws
RCScrewz.com sells vintage screw kits that are quite affordably-priced. Here's a product search for "kyosho lazer":
http://www.rcscrewz.com/advanced_search_result.php?keywords=kyosho+lazer&search_in_description=1&x=0&y=0
Been thanked: 3919 times
If your looking for the stock appearing screws, I haven't seen factory oem screw sets for Kyosho at a decent price for years. The part number was LA-58. Team associated sells metric black oxide screws in many sizes and they are a great replacement at a better price. Also check Axial and Vaterra.
Kyoshojoe
Post by Kyoshojoe »
Try the mini inferno screw set. They are not exact (heads are a tiny bit different) and not complete but you get a good amount. You can still get the fasteners from ebay by searching their size.
Welshy40
Post by Welshy40 »
Does it have to be original as i use stainless steel hex headed screws, much strong and dont wear out as much plus look much nicer and stronger
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Welshy40 wrote:Does it have to be original as i use stainless steel hex headed screws, much strong and dont wear out as much plus look much nicer and stronger
My thoughts as well.
Welshy40
Post by Welshy40 »
Also if storing the car the kyosho screws start to rust so stainless steel is the best option.
Sponser links below
Tamiyaterror
thanks for the advice guys, ill have a look round, possibly invest in a stainless set, i was originally looking for my shelf queen, but a stainless set in my vintage runner sounds just the job!
Return to “Kyosho Forum”
