Stealth 2.25 gear pitch?
General info, Q&A.
kink
Post by kink »
Is it standard to be 48 or 64 pitch?
Thanks!
GARBO 1/8
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Stealth 2.25 gear pitch?
Post by RC10th »
Pretty sure it's 48
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Stock is 48p, but you could convert to 64p courtesy of Thorp.
kink
Post by kink »
Thanks!
GARBO 1/8
Johnboy72
Post by Johnboy72 »
Stupid question. I see the 64p set on Ebay but it's for the GT. I have never owned a GT. Are the trans the same?
GT has a 2.6:1 ratio, won't work on a 2.25:1 stealth trans.
Johnboy72
Post by Johnboy72 »
2.6....too bad it wouldn't work in my RPM.
MotoObscura
Has thanked: 45 times
Been thanked: 65 times
Post by MotoObscura »
Phin wrote:Stock is 48p, but you could convert to 64p courtesy of Thorp.
What would be the main benefit of 64p? Smoother operation?
Nick DiVitto My current vintage racing lineup: Associated RC10 B2, RC10 Team Car, Losi XXT, RC10T, XX4, XFactory X5, Schumacher CAT 2000 www.moto-obscura.com My Youtube Channel
Phin
Post by Phin »
Should be smoother but I can't say how much of a benefit the Thorp 64p gears actually produced. Main reason for using 64p gears is you can fine tune gear ratios...but that doesn't really come into play with the gears inside the transmission, only the one's outside. (spur/pinion)
Users browsing this forum: No User AvatarMojeek [Bot], No User AvatarTbot [Bot] and 5 guests
