48 pitch conv on ol 6 gear tranny
OldSkoolRC
Post by OldSkoolRC »
Howdy
Looking for a diagram or instruction for the 48 pitch gear internal conversion for the old six gear. I think MIP made it but I could be mistaken. Trying to breath life back into an old friend. Thanks
Yokomo 870C, YZ-10, RPM YZ-10, Hot Dog, YR-4 M2, '91 Custom Carbon YZ-10, MR4-BX and some RC10's
THUNDERSTRIKE1
Re: 48 pitch conv on ol 6 gear tranny
Post by THUNDERSTRIKE1 »
Ive been tryn to find a diff gear 48 pitch for mine with no luck.Have everything but the diff hubs and the one gear.Don
Build it the same as you would a stock 6 gear. The only difference is the gear pitch.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Thorp made them not MIP.
flipwils11
Been thanked: 19 times
Post by flipwils11 »
I have the complete thorp 48p setup and the outdrive bearing mod (with inner bearing removal from outdrives) in my red pan/American flag rc10 build. There are faqs on it in the temple tech section if you search.
Rusty-Racing
Post by Rusty-Racing »
You can also use robinson racing spur gears as well I believe
OldSkoolRC
scr8p wrote:Build it the same as you would a stock 6 gear. The only difference is the gear pitch.
If that is the case Mine must have had some hop-ups that I forget adding since there is a series of washers and an actual bearing on the diff shaft in between the two top gears internally. That is where I think I goofed the order.
OldSkoolRC
Rusty-Racing wrote:You can also use robinson racing spur gears as well I believe
That's what it has on there now :)
OldSkoolRC
flipwils11 wrote:I have the complete thorp 48p setup and the outdrive bearing mod (with inner bearing removal from outdrives) in my red pan/American flag rc10 build. There are faqs on it in the temple tech section if you search.
Cool I will look into temple tech thanks!
