Hello all,
I recently put RPM rear arms on my Rc10. I was previously using stock arms, a short-arm bulkhead drilled for the CE inner camber link mounts, and CE length camber links with 1.32 shocks and the original 1 hole shock tower. The problem is, the chassis no longer bottoms out. The shocks reach the end of their travel with the chassis off the ground just a little.
None of the holes on the stock arm matched up with the holes on the RPM arm, so I put the shocks on the outermost hole where they just clear my tires.
I'm running the original lower spring retainers. Will switching to the spring retainers from the B4 increase shock travel?
I'm going to a BMX track tomorrow, so one way or another the chassis needs to be able to hit the ground.
Thanks.
RPM arms restrict suspension movement?
Re: RPM arms restrict suspension movement?
Anyone?
I put the stock arms back on for now, but I'd like to be able to use the RPM arms.
- RC104ever
That's weird. I had the opposite problem where it was allowing too much suspension travel. Just a guess but is it the turnbuckles that are causing the binding as a result of the hub being relocated?
- Chris
Lots of cars...so many cars
- 989 Views
Last post by cautrell05
- 190 Replies
- 20570 Views
Last post by fredswain
- 806 Views
Last post by reign79
- 1239 Views
Last post by dbs179
- 662 Views
Last post by Cplus
- 918 Views
Last post by mikea96
- 1268 Views
Last post by TheSpeedway
- 1121 Views
