Eagle Front Suspension Arms
Hi all,
I got my Eagle put back together this evening and didn't even get one pack through it before I broke the front suspension arm. The original part was 1931, but I can't seem to find any. Will the 3631 from the Stampede and Rustler work?
Thanks in advance,
Dave
Thanks in advance,
Dave
Thanks,
Dave
Dave
- TRX-1-3
- Has thanked: 2067 times
- Been thanked: 992 times
Re: Eagle Front Suspension Arms
Hey dude,
Negative, the Stampede and the Rustler use 2530 front bulkheads and they are wider at the arm mounts than the 1931 arms. You might be able to shim some 2531 arms on your Eagle bulkhead, adjusting the front to rear positioning for shock slot alignment. Clearance between the rear of the arms and the chassis might be an issue though, depending on which direction you shimmed them. But with that much hinge pin exposed, they would be more prone to bending.
Check out some 2631 arms, they are for the TCP/ TRX-3. They will be a little shorter than the 1931's but they will fit the bulkhead and the caster blocks for the Eagle. They are still available. Again though, I am not sure with the shock slot alignment. Pretty sure the caster blocks would fit the 2531 arms though. The shock slots in the arms are wide and they come with aluminum spacers. You may have to shim the shock tower off the bulkhead to line them up.
OR:
There is a lot of room to drill holes on a 2530 bulkhead. You could line it up, clamp it to the chassis, drill the mounting holes, lash it up and run with the 2531 arms. Same deal with the shock tower.
I haven't done it with an Eagle but 2630 bulkheads are hard to find and I have trimmed up 2530's to fit the TRX-3 and accept 2631's.
Jeez, long blurry post. Do your own math, but those might be some options.
Mark
OR:
Mark
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
you breaking white or black arms?
klavy69 wrote:you breaking white or black arms?
They were the original white arms Todd.
Thanks,
Dave
Dave
- klavy69
- Moderator
Dave,
that I can understand. I ran a 1931R set on the front of my eagle thru some pretty punishing bashings...read cartwheels into that and never broke a set that didn't deserve to be broke
. Not really sure of anything from the current lineup that could be fabbed to fit but let me dig to see if I have some 1931r still hanging around...
All,
I got hooked up with some arms, thanks to the great folks on this board. I really appreciate the input and help!
Dave
Dave
Thanks,
Dave
Dave
- 1639 Views
Last post by Badmuthatrucker
- 190 Replies
- 20618 Views
Last post by fredswain
- 807 Views
Last post by reign79
- 662 Views
Last post by Cplus
- 918 Views
Last post by mikea96
- 1268 Views
Last post by TheSpeedway
- 713 Views
Last post by RC104ever
- 1121 Views
Users browsing this forum: stickboy007 and 7 guests
