Avaliable lower profile LiPos to fit our old chassis?
- DerbyDan
- Been thanked: 19 times
My first ever LiPo was a gold TrakPower 3600mah 25c pack, but despite being retired from powering my modern touring car its led a busy life since powering all of my vintage racers (Losi XX, XXT, JRX2 & my Worlds RC10) Simply because its the only LiPo battery that I've ever owned that is slim enough to slide into the chassis & be captured at the rear by either the chassis or the bulkhead.
Unfortunately this old battery will eventually die & has also been long discontinued, so I wondered if anyone out there has found a supply of suitable LiPo batteries that fit into our old vintage buggies & that are still avaliable? Perhaps we could formulate a list that could be posted in the 'Modernising our Vintage RCs' 'sticky' thread?
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: Avaliable lower profile LiPos to fit our old chassis?
These are good for just about anything that would fit old stick packs. Especially helpful with old Tamiya vehicles. A couple of other companies make a similar pack.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAVHP&P=7
a little more capacity
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYYS5&P=7
EDIT: That second one is discontinued now that I look closer, but I think most companies make at least one battery in this configuration now. I was really happy to see them become available.
- THEYTOOKMYTHUMB
You might doublecheck the thickness, but I think this will work as a 3s option just in case you want to destroy a car(
)... once it's back in stock.
http://www.hobbypartz.com/83p-2650mah-3s1p-111-25c.html
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
SMC 3200's fit with room to spare, last during a 10min main with a 10.5-DerbyDan wrote:My first ever LiPo was a gold TrakPower 3600mah 25c pack, but despite being retired from powering my modern touring car its led a busy life since powering all of my vintage racers (Losi XX, XXT, JRX2 & my Worlds RC10) Simply because its the only LiPo battery that I've ever owned that is slim enough to slide into the chassis & be captured at the rear by either the chassis or the bulkhead.
- Been thanked: 325 times
Here is another option; I'm using these for my Kyosho Optimas, which need a vintage size & shape: Gens Ace 2S1P 4000 mAh, it's even cheaper than the Associated ones @ Tower with lower capacity:
http://www.hobbypartz.com/98p-25c-4000-2s1p-hardcase-direct.html
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
the Orion Carbon series that have the bulges work - put the bulges up
Discontinued, but easy to find, still
Paul
Paul
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
Traxxas 7.4V 4000mah LiPo [2841], fits perfectly in a stock RC10 or JRX-2.
They are a bit pricey, but good quality / long run time.
-dldiaz
- RC104ever
Any Gens Ace 5000 mah 2S will fit, with a bit of wiggling. They are AWESOME.
- Chris
Lots of cars...so many cars
They won't fit every vintage RC car though, as they have squared edges. Many cars from back in the day need a battery pack with an oval-shaped cross-section. The RC10 is a bit different, but I figured it was necessary to clarify this.RC104ever wrote:Any Gens Ace 5000 mah 2S will fit, with a bit of wiggling. They are AWESOME.
- Orange
I have a thunder power 5300 in my RC10, fits in the rear bulkhead... Have to use a battery cup with front part cut out though. It will last 36 minutes with a 17.5. (Yes I know for sure on the time)
- DerbyDan
All great suggestions, thanks everyone
@ Reggie - are those SMC batteries still avaliable? They don't seem to be listed on their own website?
I like the idea of the packs that reasemble the old Nicad/Nimh stick packs with the radiused edges - as I could also use those in my Tamiya Mini & Clodbuster!
If your willing to cut the end of the battery cup, Venom Lipo's will fit. It fits up against the servo mounting block. Below is a pic of a Venom Lipo in my WOIN world car.
NEW: SC10 4x4 FT, SC10 FT, (2)T4.1 FT, B4.1 World
OLD RC10's: (4)Worlds, Graphite Team Car, (2)RPM Ultra's, Tekin, B2 Team Car, B3, (3)Champ Editions, Team Car, (2)RC10T Team Truck
Tamiya: Hornet, Fox
Bolink: Invader
Losi: (2)XX, Junior 2, JRX Pro SE
Tamiya: Hornet, Fox
Bolink: Invader
i fit turnigy 4000mah 40c hardcases in my rc10's ad jrx's.
i use orion rocket pack 3500mah 25c's in my m03's and tamiya's that use rounded packs.
- DerbyDan
Neat electrics install there Chris!
It seems the majority of the LiPo packs are 'too long' compared with the NiCads of old, but in my RC10 & JRX I've used the AE battery cups which have a nice large flat base to stick them down further forward than originally intended - I use 3M VHB tape which is super strong. The XX buggy was designed so that the battery pack can be moved forward or back as a tuning aid so there's no problem with the pack length, although the battery height & shape is perhaps more critical because of the ridges either side of the recess restricting how low the modern size LiPos sit down - again the rounded sided packs are better suited here.
- 1380 Views
Last post by klavy69
- 20 Replies
- 5026 Views
Last post by RCveteran
- 508 Views
- 660 Views
- 2236 Views
Last post by Hcp22
- 22 Replies
- 2132 Views
Last post by JK Racing
- 1252 Views
Last post by Lee_123
- 704 Views
Last post by mrluckies
Users browsing this forum: Amazon [Bot] and 3 guests
