Moody "drive pack" gas conversion
Been thanked: 3919 times
Roy Moody's RC10 gas conversion kit. Thanks to Marlo I now have a couple of em. I have a minty chassis ready to be drilled on but for this one I used a used up chassis so I know where everything will go. I don't want to be Mis-drilling on the new chassis.
Starting with the clutch, very odd design. The shoes are barrel shaped and do not drag like a typical design. Never mind that its on the wrong end of the engine. CZ-2 rear start shaft is turned down to become the shaft that the clutch rides on. This is on a CZ-R with the CZ-2 crank and rear start assembly. This design seems to have been for balance and keeping the engine centered side to side
More to come as the build progresses
j-sou
Re: Moody "drive pack" gas conversion
Post by j-sou »
Really cool! Can't wait to see it complete! :mrgreen:
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
Are those the two that were on eBay recently in the lot of stuff in the team car box? I wanted to get one and sell the rest of the lot but it skyrocketed well above my price range.
That's an interesting muffler, is that part of the conversion? It looks like it is using an O.S. airplane style muffler on the box.
Yes, same kits. They flew to Canada for a few weeks and then back to the USA :mrgreen:
The muffler is odd, points directly out the bottom of the chassis. Not sure what the theory is as a airplane muffler would have been fine, but you can loosen the clamp and clock the outlet making me think its a back pressure adjustment. Hard to say, I will know more when and if I get my hands on the instructions. I found someone that has them and I'm working on getting copies.
Definitely a odd bird!
Has thanked: 356 times
Been thanked: 470 times
If I remember correctly, they are helicopter motors-
I think I recall what you are referring to (but cant place the application....) but this kit is actually a production OS CZ .12 based kit with a machined down starter shaft. It had all the pieces with it in the box :mrgreen:
saga101
Post by saga101 »
cool kit :shock:
I AM CARL LIN
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
Is there room for a battery?
This is all very interesting!
romulus22
Post by romulus22 »
a01butal wrote:Is there room for a battery?
Behind the bulkhead where the motor would originally be is where they mount. Just like a first gen GT
Yes, I would go as far as to say that associated copied battery placement and throttle servo placement, and ignored the rest :mrgreen:
romulus22
Post by romulus22 »
gomachv wrote:Yes, I would go as far as to say that associated copied battery placement and throttle servo placement, and ignored the rest :mrgreen:
Do you know the release date on these kits. IDE say the Dudgeon conversion also had a big influence on Associated. Besides it being a double decker chassis the GT is almost identical to it as far as component layout goes.
Also Kunio in another thread said he sent off his conversions all over including Cliff Lett. Even Kinwald raced one before the GT
The Moody stuff was also based solely to be raced on Dirt Ovals- No where near as robust as the Kunio kit-
Jeff, do you have the right tires and wheels?
I have the early prolines you showed in the other thread and also some Imex "California" that are early 10t so I think I'm covered there. I'm loving those tires shown in the moody paperwork...are they Imex? Or do they look familiar? I may just use the foams i already have. I can't see going off road on this conversion either, there are a couple braces but the belt is very fine pitch and as Reggie stated- not a very robust kit.
I am not positive on a release, i was thinking 91ish but there is a "1092" at the bottom of a page I found. This model has a few differences between the others I have seen like the exhaust and panda fuel tank so I don't know if that really is a date but it makes sense.
The kit pics would be Advance Engineering 5 slot 1/8 wheels, with MRP Grand Prix tires. (or Look around here for the Moody sprint or Kendrick Sprints and you'll see them. Proline Striker II tires were very popular oval tires too, or I can show (or do) you how to groove foams to look just like the MRP tires (but the Coopers rims are way too late)
Strikers may be the way to go, I bet the mrp tires are near impossible to find as I haven't had any pop up in any eBay searches for mrp in the last year. So....would it be obvious if I used duratrash tires instead of striker II's?
I figured those foams were too new but good to know. Drat!
I scored a parts truck to finish this conversion on. I needed white parts and found a nice little narrow front tire truck cheap. Hopefully it cleans up well. That keeps me from needing to use the upgrades from the other thread too, although the tecnacrafts may go on it. Still undecided on the A&L towers, they just look too new to me. Would Duratrax towers be closer to the right era? I think I know where there may be a set
