Gas conversion RC10T
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
See post #43 for current pictures. All other pictures lost…..
Going to base this off of what someone would have built in the beginning of the nitro craze before conversion kits were available. Only sacrifice to original parts will be a used chassis. Trying to not modify any other parts that can't be returned to factory later down the road.
So far all I've done is notch the chassis and mirror a bunch of parts. I'll get some thicker scrap alum that will bolt to the left engine mounts and behind the baseplate. Will use a band style brake off of the clutchbell, and a muffler that will exit out the rear through the shock tower.
Here is a few pictures to show where I'm going with this. Still a ways away but you'll get the idea.
Running out of things to do that don't require tons of money or elusive parts that I can't get ahold of so I'm starting a new project I should be able to do with what I already have minus a few home made pieces.
Been thanked: 3917 times
Re: Gas conversion RC10T
Very cool! I had built a blue eagle into a nitro bitd, used a duratrax clutch setup and some kyosho mounts, had to run an idler cause the lay shaft had to exit the left side of the truck on that diff.
I wonder where all the dudgeon and amain conversions went. I haven't seen one in years!
justinspeed79
Post by justinspeed79 »
Cool project! Looking forward to following you're progress. 8)
romulus22
Post by romulus22 »
Found some scrap in a bin. This will be my engine mount. Needs tigged in a couple spots and cleaned up a little but it should be pretty solid mounted to the bottom and side of the chassis.
And that's all for tonight. Dinner, laundry, then bed.
DHood
Post by DHood »
I have two dudgeon trucks, One restored and one in peices. That's one good thing about working at a sign shop, Always plenty of scrap metal :D
romulus22
Post by romulus22 »
DHood wrote:I have two dudgeon trucks, One restored and one in peices.
I'm always on the lookout for these. I know that when one finally shows up it will be way out of my price range. Always someone willing to spend more than me. Unless its poorly listed and I'm the only one who sees it which is rare due to all the other people who are good at finding those too.
DHood wrote: That's one good thing about working at a sign shop, Always plenty of scrap metal :D
We have an over stuffed lot full of it. Almost any size and thickness I could ever need.
romulus22
Post by romulus22 »
One more thing for the day. Had to change my idea of running the exhaust out the back through the shock tower because the muffler would have been higher than the body post. Already going to have to cut shock openings so the body will need some structure to stay sturdy. This way is still clean I think. Arm just touches at full compression and I could turn it more if I really wanted.
Also looking at my engine mount, it will be painted black and will almost blend right in with the chassis side.
If you decide to try a tuned pipe, the header for the kyosho stinger is made for an engine at that angle. That's what I ran bitd.
romulus22
Post by romulus22 »
I haven't really tried to stick a body on there but I'm thinking the engine sits too far to the side to run any pipe off the side without major trimming.
tommykart
Post by tommykart »
Really cool project.
Tom
romulus22
Post by romulus22 »
Progress was cut short due to a broken tap. But still managed to tie in the rear pretty good. Really solid and it still has one more mount by the peice of black delrin that will be tied down to finish it off.
Here's the upper/lower chassis brace with rear mount integrated. Keep in mind ill go back and smooth all these pieces out. They are all just roughed in for now.
romulus22
Post by romulus22 »
Tonights update.
Braking and throttle in position, just need some stops and springs.
Threw some wheels on to get an overall picture too
justinspeed79
Looking good. 8)
Has thanked: 3699 times
Been thanked: 1980 times
Damn, that is coming along nicely. Good vision on the way you pieced all that together. 8)
USA-1
Post by USA-1 »
Good McGyvering, How are you planning to start it pull?
Return to “RC10 Truck Forum”
