RB5 / ZX-5 Big Bore shock dimensions?
kink
Post by kink »
I am interested to know the length of the shocks measured between the centre holes, front and rear.
If you have some to measure please PM me :)
Thanks so much!! :)
GARBO 1/8
Has thanked: 356 times
Been thanked: 470 times
Re: RB5 / ZX-5 Big Bore shock dimensions?
Kyoshos' website has it listed, but they are "industry standard" buggy length-
kink
Post by kink »
Thanks, I found out the fronts were too high and the rears too short. What industry standard? They are all different :D
Anyway I decided to stick with retro and go for old Kyosho Golds. Well I have the rears anyway, so halfway there.
GARBO 1/8
kink wrote:Thanks, I found out the fronts were too high and the rears too short. What industry standard? They are all different :D
How much too long or short? I think differences up to 5mm or so are easily changed by adding spacers inside the shock pistons and/or changing ball ends. You can increase a shock length even more easily just by changing the ball ends.
kink
Post by kink »
I am now just getting the retro shocks I want then getting custom carbon fibre towers made to match them perfectly. So it is not an issue.
But also I decided I should stick to a retro theme, or it would be too mix and match. So the theme is retro hop up's.
GARBO 1/8
Return to “Kyosho Forum”
