Losi LXT Duratrax Gas Conversion
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
Does anyone know the source of the right outdrive for the transmission below? I'm attempting to rebuild a Losi LXT/Duratrax Gas Conversion truck. As can be seen in the photo, the outdrive is deformed, and will not hold the drive shaft in place. The the outdrive looks like it's made by Losi, but it's a wider diameter then the LXT, and it houses ball bearings.
Thanks, Limestang
LXT Conversion.jpg (52.57 KiB) Viewed 1956 times
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Re: Losi LXT Duratrax Gas Conversion
Post by aip47-2008 »
Those look like LRM (JRX2) out-drives.
limestang
Post by limestang »
Thanks aip47. What does LRM stand for?
Been thanked: 3919 times
Low rotating mass
(5 gear)
limestang
Post by limestang »
Thanks for the help, you put me on the right track. The Losi LXT I was using was based on an Lxt conversion. This uses an older transmission design and the out drives don't work on the Duratrax. I found true LXT outdrives and they fit.
Now I have to work the next problem - No motor mount or clutch assembly. A unique feature on this particular Duratrax Gas conversion is it uses the Losi 48 pitch spur gear and slipper clutch assembly. I have not been able to find any information on this configurations so am stuck until I find instructions and parts
Return to “Losi Forum”
