Anyone else have this problem?
- Regular Member
When I install my battery pack, the wires have to make an immediate 90 degree bend upwards and rub hard on the steering servo. There isn't enough room so the wires can come out at a better angle. Is there something I can do to correct this?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Anyone else have this problem?
Stick pack or ??
Where is the battery cup in this fiasco? I have cut the holder to allow a little room for the wires to exit but the servo should be a bit forward still. A pic would help
- Regular Member
- Has thanked: 36 times
- Been thanked: 1318 times
- Regular Member
Never thought of that. Is that my only solution? Is this a common problem, or is this just a long pack?scr8p wrote:take the black end cap off of the pack.
well, you could cut the ears off of the servo so you can slide it forward and attach it with servo tape.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
- Regular Member
I might try that first, i already have some double sided tape. its not servo tape but maybe it will be strong enough to use. thank you for the help!!well, you could cut the ears off of the servo so you can slide it forward and attach it with servo tape.
nope, 6 cell 4000 mah team orionHas to be a 7 cell pack-
- Regular Member
People usually use NiCad's in these?jwscab wrote:yeah, NiMh, longer cells.
Back in the day
A lot of the plastic caps had cutouts so the wires could run 90° as needed on these when mounting side to side.
Notching or removing the servo mounts as mentioned are also very easy solutions
- Regular Member
Here's the end result, ended up getting some servo tape and it worked perfect. Thanks
- RC104ever
The lipos I use don't have this problem but the NimH battery does though.
- Chris
Lots of cars...so many cars
- Regular Member
When I pulled this thing out of the closet, my plan was to get it running on the cheap. I did not want to put a lot of money into it so i purchased a cheap motor and esc. But i have fallen in love with it again lol and now I am wishing I would have put the money toward lipo's and a BL setup. Maybe if work gives me some more OT, i'll throw those parts in the parts bin and get my BL setupRC104ever wrote:The lipos I use don't have this problem but the NimH battery does though.
- longboardnj
- 1866 Views
- 888 Views
Last post by Steve71
- 2466 Views
Last post by 8rad
- 514 Views
Last post by ireg
- 2473 Views
Last post by Jay Dub
- 2841 Views
Last post by rcyeddo
- 733 Views
Last post by Trumptone
- 779 Views
Last post by shane
