Login problem.
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Login problem.
I must login every hour or so. Checking "Remember me" and "Log me in automatically" does not work. Only on my work PC, my home PC works fine.
Running Firefox on Windows XP.
Any ideas?
Any ideas?
- Jirka
- Has thanked: 33 times
- Been thanked: 24 times
Re: Login problem.
If You don't klick different pages every now and then, same happens to me too with Windows, Linux and mobile phone. I think that it is a security feature.
Jirka
Jirka
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
- 8rad
Re: Login problem.
Maybe.....but even if that were the case I should still be able to re-login without retyping my username and password. As it is now I have to re-type in my user name and password every time.
It seems like my browser wont save my settings. If I check off "Remember me" the next time I log in it is "unchecked".
- Been thanked: 325 times
Re: Login problem.
Sounds like you may have configured your browser to delete your history after every time you close the browser. In Internet Explorer, go into Tools > Internet Options and look in the "Browsing History" section. Make sure you don't have a checkmark in the "Delete browsing history on exit" box. There must be something similar in Firefox, you'll have to look for it. I've seen that option enabled causing exactly the problem you describe, where you need to login each and every time you reconnect to a website with a login.8rad wrote:Maybe.....but even if that were the case I should still be able to re-login without retyping my username and password. As it is now I have to re-type in my user name and password every time.
- 8rad
Re: Login problem.
Your right Coel. I had "remember passwords" disabled.
I knew it was something simple. Thanks to all for your help.
- 514 Views
Last post by ireg
- 22 Replies
- 1517 Views
Last post by THEYTOOKMYTHUMB
- 1851 Views
- 2282 Views
Last post by suby56
- 880 Views
Last post by Steve71
- 775 Views
Last post by RC104ever
- 1927 Views
- 826 Views
