Brushed motor with broken brush
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
So I was testing some vintage electronics tonight, and noticed that the brushed motor I had seemed to run at full throttle just fine if I increased the throttle slowly, but not if increased quickly. Most of the time. Sometimes it just worked fine.
I checked the brushes and discovered one was not moving smoothly. Turns out it was broken in half. What can cause that? Can I just replace the brushes with fresh ones, or is the broken brush a symptom of more damage to the motor? The collector seems a bit dirty.
THUNDERSTRIKE1
Re: Brushed motor with broken brush
Post by THUNDERSTRIKE1 »
Take the springs off holding the brushes in pull the brushes out inspect the comm if no scarring just clean it out and use comm stick on the comm and replace brushes.More than likely it had taken a direct hit on the motors endbell .If brushes are really discolored maybe it was geared wrong an overheated the brushes which causes them to deteriorate.DON
brushes are brittle, so a hard hit in the right spot can chip or crack them. just replace and check for smooth movement in the brush hoods and keep an eye on it.
EvolutionRevolution
Okay, thanks. The comm doesn't look too good, so I swapped the motor for another one.
Jay Dub
Post by Jay Dub »
Collector?
EvolutionRevolution
Jay Dub wrote:Collector?
Comm. Language oopsie.
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
I think both collector and comm are the same, it depends where you live... :wink:
Cheers
Lars
My Feedback
Users browsing this forum: No User AvatarTbot [Bot] and 3 guests
