SIX GEAR QUESTION
JOESGARAGE
SIX GEAR QUESTION
Post by JOESGARAGE »
Just got a six gear transmission off the bay. Opened it up to see it have all metal gears and bearing through out, is this a up grade?. Is it safe to run brushless set on it?
OLD SCHOOL!
shodog
Been thanked: 91 times
Re: SIX GEAR QUESTION
Post by shodog »
Basically the ideler gears have been upgraded. Were they 32 pitch or 48?
JOESGARAGE
32 pitch, going to switch to 48 pitch.
OLD SCHOOL!
JOESGARAGE
gears inside? look like 32 pitch.
OLD SCHOOL!
abailey21
Post by abailey21 »
Do you have the part numbers for switching the slipper assembly to 48 pitch on the 6 gear? I've been searching with little luck
Been thanked: 1319 times
the 6 gear doesn't have a slipper. what you see is an external diff. the only thing need to change the spur to 48p is to buy the appropriate style 48p spur and put it on. i normally use kimbrough spurs.
abailey21
Post by abailey21 »
And thats why I couldn't find any part numbers....thanks man :)
need-a-cage
Post by need-a-cage »
Is this the appropriate style? Also, what size "dif balls" go in this spur gear. It takes a lot more than the stock spur and I am not sure what size. Are they 3/32, 5/64, or something else?
http://www.ebay.com/itm/350558666767?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/230785995270?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
http://www.ebay.com/itm/140743019855?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks!!
6 gear uses 1/8" diff balls.
JOESGARAGE
so ok to run a 21.5 brushless system on it, since mine has all metal gears?
OLD SCHOOL!
need-a-cage
Will the spur gears in my link above work and do they use 1/8" balls?
Thanks
with all metal gears, it should be bulletproof, and the only thing that will break is you will probably melt the spur gear since there is no slipper. I would probably put some kind of lube in the gearbox since you will have metal on metal.
yes, the above spur gears posted will work for the 6 gear diff and use 1/8th balls.
need-a-cage
Cool, thanks for the info.
Do you load all 18? My stocker only uses 8 I believe.
BTW, what pitch is the stock spur on the original RC10's?
Thanks again.
it's whatever lines up with the diff rings. I think stock was 8, some gears you can put more in. doesn't really matter as long as they line up on the steel diff ring. Obviously in a symmetrical pattern.
32 pitch was the original gear, but it changed to 48 pitch in later versions.
JOESGARAGE
Thank you!
OLD SCHOOL!
