Resizing my Avatar
ireg
Resizing my Avatar
Post by ireg »
I surrender :cry:
I acccidentally deleted my avatar and now trying to replace it, but cant get the requirements (130 x 400 size 8kb) without suffering the quality of the image.
Why other can make their avatar big and pressantable, mine so tiny and you can hardly see the image.
here is my avatar
i can not resize, any input to make the size smaller will be appreciated.
and here is the result when i tried to resize it
happy me 2.jpg (9.16 KiB) Viewed 1277 times
Mindwarp
Re: Resizing my Avatar
Post by Mindwarp »
7.94k
I used Gimp to crop it a little and then save it as jpg with more compression.
Halgar
Has thanked: 146 times
Been thanked: 197 times
Post by Halgar »
The easiest way to get into the parameters are to crop the image as much as possible and resize it to the requirements of the site. From there you need to "export" the image, which will strip off all the meta-data and turn your 20k image into a 3k to 5k image, well within the constraints needed.
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
Here it is without the cropping:
Mindwarp
Post by Mindwarp »
Awesome, did you just reduce the quality? I had the one I did down to 63%
Lowgear
Post by Lowgear »
I'll PM you as to not divilge my secrets. :shock: :mrgreen:
Mindwarp
Post by Mindwarp »
lol, my lips are sealed!
ireg
Post by ireg »
WOW!!! thanks guys that fast, I tried to resize this for more than 1 hour now but no success :mrgreen:
farmer
Post by farmer »
where do u export it to?
farmer
Post by farmer »
NV/M thx
Lowgear
Post by Lowgear »
I was bored so I did this which should also work:
(Only looks good on the default 'AcidTech Tiger' skin though)
Halgar
Post by Halgar »
farmer wrote:where do u export it to?
farmer wrote:NV/M thx
I'mma gonna tell ya anyway! :mrgreen:
You're not exporting it anywhere, at least not with Adobe Fireworks, which is what I use for such things. You can change the name and location of the file if you want to, but I never do. My edits of an image get different names from my final image, which is then exported into the same folder with the same name.
Has thanked: 3699 times
Been thanked: 1980 times
Lowgear is pretty handy with computer and internet stuff. :wink: He's helped me out quite a bit. :D
Jayar
Post by Jayar »
I use windows paint that is on all pc's.
Just right click any your avatar, choose open with then paint.
Now you will see the pic in its actual size.
O.K. now drop down the image menu and choose resize.
The two boxes that say 100 can be changed to 50 to cut it in half 25 for 1/4 etc.
If that isnt right click undo and it will go back to 100.
keep trying different numbers until you get the size you want.
J.R.
Lowgear
Post by Lowgear »
THEYTOOKMYTHUMB wrote:Lowgear is pretty handy with computer and internet stuff. :wink: He's helped me out quite a bit. :D
Hehe thanks, though I better be since its my job. :shock: :mrgreen: When you need anymore help just ask. 8)
Jayar wrote:I use windows paint that is on all pc's.
J.R.
We're talking about file size not physical dimensions. :)
