Aluminium front/rear arm thickness?
General info, Q&A.
Hakase
Post by Hakase »
How thick are those aluminium front/rear arms?
If RC10CE inner hinge pin diameter is 1/8"(?) (3.175mm),
will 6mm aluminium be enough since there's only ~1.4mm per side where hinge pin goes...
At least is sound quite thin so it could crack after first jump...
How thick are those klein arms?
Has thanked: 33 times
Been thanked: 1178 times
Re: Aluminium front/rear arm thickness?
klein arms are 6mm.
