arm mounts- front and rear
as i finish making my list of items to build my runner i ran into another question.
when using the truck front and front bulk head, i assume you have to trim the bulk head to fit the Andys arms? the 10T i have at home has a wider area where the arm mounts.
On the rear arms if i brake a mount, is there some thing current i can use with out making new holes in the chassis?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000240864&I=LX3387&P=K
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000240864&I=LXVC42&P=K
Re: arm mounts- front and rear
ok, let me as this on the front, will the RPM buggy arms fit the truck front mount?
Not sure about the 10T Bulkhead, but is this the wide Nose plate 10T? for the rear mounts if you use the one you posted, i think you would need an RPM Worlds Rear Arms, similar to this one geeforce orange 10, Finding one would be very hard but dynotech makes replica of it in white delrin nylon. http://dynotech-racing.com/partDetail.php?RefNum=2700 , http://dynotech-racing.com/partDetail.php?RefNum=2701
mod was made for the rear Arms mounts to fit using a RPM worlds arms. there are still lots of stock rear arm mounts being sold at ebay, you can also try the BST area.
cheers!!!
cheers!!!
― Confucius
― Confucius
ok, what is that chassis. I searched the board for it LOL
I see the rear arm mount holes are different from my T chassis. Lookin for suggestions for rear arm mounts for a 10T that will fit my chassis.
thanks
thanks
it was tailored to fit a World Arms length. can you post your chassis so that we are on the same page.
― Confucius
― Confucius
i can tomorrow but it is a standard black alum pan chassis with stealth tranny and the stock arms mounts the buggies and 10Ts came with.
any standard Arm mounts will do, there are lots of them on ebay. that will solve your problem.
― Confucius
― Confucius
- 1844 Views
Last post by cowsrneat2002
- 508 Views
- 1241 Views
Last post by ELF-BMX
- 1734 Views
Last post by templeofspeed
- 1165 Views
Last post by longboardnj
- 160 Replies
- 13156 Views
Last post by SnoopMaxx
- 537 Views
Last post by Asso_man!
- 1166 Views
Last post by Toasted Coastie
