Catbits quiz...
Jools
Has thanked: 6 times
Catbits quiz...
Post by Jools »
Slowly getting the hang of these cats, but I've got a few parts which I need I.D'd
A: Front trans, -no slot for tensioner plate ?
B: Layshaft? -Pin positions look different to my procat manual ?
C: One way shaft part ?
D: Thrust bearing...what off ?
E: Coarse tooth belt and thrust race pinion ?
F: Wheel adaptor ?
G: ?
H: like a centre/diff pulley but with no ball holes ?
Cheers, Jools
8rad
Has thanked: 9 times
Been thanked: 38 times
Re: Catbits quiz...
Post by 8rad »
E is a YZ10 pulley and belt.
F is a wheel adapter for Yokomo wheels on your cat.
G is a rear upper suspension mount.
H is a rear diff gear. Original cat diff has three. Only the middle one has diff balls.
(Anyone got any rear transmission housings they can bear to part with?)
Talk with CATS. He has a pile.
moozo
Re: Catbits quiz...
Post by moozo »
A= would be from the any cat before the procat, ie xl/xls etc
G= the same as above
Jay Dub
Re: Catbits quiz...
Post by Jay Dub »
Let me know if you want to part with the yokomo wheel adaptors in the pic. I recently purchased a set from a member here, and one of them has stripped holes :roll: . So, I need one to round out my set. LMK Thanks -Jeff
john73
Re: Catbits quiz...
Post by john73 »
All parts excluding E & F are original CAT SWB & XL (not XLS or procat)
Have a look at the instructions, these will help as it shows images of the part and where they go
http://www.retromodelisme.com/manuel_page/3/cat-schumacher.html
http://www.retromodelisme.com/manuel_page/53/cat-xl-schumacher.html
Hope this helps
John
4x Procat
2x Cougar
1x Cat XLS
Jools
Re: Catbits quiz...
Post by Jools »
That's cleared that up then, mostly early Cat, Ta boys. (What's a YZ10 Brad?) 'scuse my ignorance!
Jools
Has thanked: 1737 times
Been thanked: 1145 times
Re: Catbits quiz...
Jools wrote:That's cleared that up then, mostly early Cat, Ta boys. (What's a YZ10 Brad?) 'scuse my ignorance!
Jools
That'd be a Yokomo, matey... welcome aboard!
8rad
Re: Catbits quiz...
Post by 8rad »
http://www.rc10talk.com/viewtopic.php?f=29&t=2654
Yes. Welcome!
Return to “Schumacher Forum”
